What do I need to make 64 inputs?
I have a long term live recording gig coming up. The board will be a Digico SD9. We plan to take the direct outs into an SSL madi card which will feed the computer. This mac pro also has 2 HD cards installed, but in this scenerio unused. It doesnt seem to be working with more than 32 inputs with protools 10. Will upgrading to protools 10 HD solve this even tho the HD cards are currently unused? What might I need to buy to get all 64 inputs from the madi system working in protools?
The avid spec sheet for protools is very unclear. Thanks
Frost Owner Narnia Studios |
Re: What do I need to make 64 inputs?
You need a Madi Interface.
And Digico is just supporting 56 channels.
www.srs-mastering.de Mac Pro 6.1-8core, OS 12.6, PT2023, HDX2, Sonnet Echo Express III-R, Madi Interface. |
Pro Tools 10 non HD can do 96 tracks at 48K... sounds more of a hardware issue than HD versus non
Here is the link to the comparison... http://www.avid.com/US/products/Pro-...atures#Compare |
Darryl |
lol... Wah wah... yup.. I was looking at playback...
Do you need to record in Pro Tools? Consider something else to record and then bring the tracks over if you don't absolutely need Pro Tools on the tracking side.
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 | | Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 | |
Or you rent it for a couple of days.
Or you'd use something like Nuendo/Nuendo Live or any other DAW to record in. They will all support your SSL madi interface.
I have the ssl madi interface, was just hoping I could use it and protools HD with the HD cards I have (hd cards doing nothing) to track in protools hd. This will be an ongoing project for a specific band who owns the board and wants to track every show so renting isnt an option. Ill have to decide if I should just track in something else or pony up for the avid madi interface.
Thanks
it's 48 flexi channel mono or stereo.
192 analog inputs make noises | Detlef Brockmann | Pro Tools TDM Systems (Mac) | 5 | 04-15-2011 01:18 PM |
Using Eleven Rack inputs like POD X3 inputs | dayslypper | Eleven Rack | 1 | 10-09-2010 09:15 PM |
Analog inputs 5-8 not seen as inputs on tracks | sitarartist | Pro Tools M-Powered (Mac) | 4 | 09-16-2010 08:24 AM |
How do I utilize the Line inputs when all my XLR inputs are being used? | 007audio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-23-2009 08:21 PM |
how to make a template that will make LE 5.3 stay put over two monitors?? | lavoll | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-10-2003 03:43 AM |
