Old 11-05-2009, 07:25 AM
PodBoy9 PodBoy9 is offline
Default Alternate power supply for Magma?
Hi, I have the
THE 13-SLOT Digi chaise. PCI13R68DIGI
I need a power supply, have any of you used a stock ATX LIKE THIS http://www.atxpowersupplies.com/400-...wer-supply.htm
Just wondering, the Magma 400w is $300.00 seems to be the same "mostly".
Old 11-05-2009, 07:50 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Alternate power supply for Magma?
Originally Posted by PodBoy9 View Post
Hi, I have the
Any good ATX PSU 400-600 watts should do it! make sure there's at least the same amount of amps or more on the atx power. some make more noise than others! and newer one's have slightly different connectors (24 pin) but still work on 20 pin atx sockets as the extra 4 pin connections are optional.
Producer, Engineer,
www.ukmastering.com
Old 11-05-2009, 11:13 AM
sunburst79 sunburst79 is offline
The Corsair HX series are VERY quiet. I've run both the 620 and the 525 and they both nice. Retail runs around 120.00 and there are usually rebates out there.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Magma PE6R4 Power Supply ZEUSS Pro Tools TDM Systems (Mac) 15 08-19-2015 01:58 PM
Magma PE6R4 chassis power supply #3 crizdee Pro Tools TDM Systems (Mac) 3 02-16-2013 10:54 AM
OT:Help w/ Installing a New Power Supply in a Magma PE6R4 lownotesinc Pro Tools TDM Systems (Mac) 2 09-14-2010 04:06 AM
Magma PE6R4 Power Supply sinkrock Pro Tools TDM Systems (Mac) 7 12-01-2008 08:52 AM
Exchanging Magma Power Supply KaiXXX Pro Tools TDM Systems (Mac) 1 06-10-2007 05:01 AM
