Delay Comping for no reason
Look at the numbers. This only happens on AUDIO tracks and there are no hidden tracks and the track showing orange(7 samples) has the highest plugin latency. I can't for the life of me figure out why the 1024 readings exist! and, why is it only on AUDIO tracks? If I try to track like this, the latency in the phones is awful, but as soon as I disable the compensation, everything sounds/works fine for tracking.
Re: Delay Comping for no reason
what buffer setting are you at ?? could it be that the Buffer Setting is showing in the ADC readout ?? if you change your buffer - toggle it from where it is to another value .. does it change down there ?? i do not run HD so i cannot perform an apples to apples here for you ...
post a pic of the routing & sends.
All tracks feeding the main outputs. A single VCA for the drums. Any AUX tracks are fed via AUX sends from AUDIO tracks. That's it Nothing fancy, nothing routed thru a bus. Each track has 5 sends feeding outputs(for headphone mixes). Also, its not consistent to every session. I've been doing this stuff for years and this just makes no sense to me. Next time around, I will try trashing prefs again, but its a head-scratcher
That is a head scratcher.
PT 11, PT LE 6.0, DIGI 001, DIGI 003, 27" Late 2012 Intel iMac, Blue and White G3, Reason 7, Celemony, Waves, A.I.R., Softube, XLN Audio, IKmultimedia, Massey Alesis Masterlink, Alesis Adat LX20, , Yamaha Motif ES8, Sure SM58, Sure KSM27, Byerdynamic MC 834 N, Event Project Studio 6, Pod Line 6, Focusrite Trakmaster Pro DI, Glyph Drives, Lexicon, Fender Strats, Ibanez Acoustic, Ibanez Bass, Ibanez Electric. http://www.johnackermusic.com/ [email protected] Live and Let Live |
That's some pretty serious compression you've got going on there.
Or gating/expansion.
Dead auxes can mess up delay comp. Are you sure that all 5 of those auxes for headphones are always going to active output? |
Valid question, and yes they are all routed to active outs. Any time I open a session with any routing greyed out, I have to fix it due to the OCD in me. But since I am also ADD, I only need things to be just right.....for a few seconds......
Still having this issue randomly. Would sure love to figure it out Meanwhile, I have to kill ADC for tracking and remember to put it back on for mixing..................
hey Dave. i'm with Drew...you should show routing so we can get full picture of what's going where and what's on inserts. VEPro is not involved right? what does your system delay show?
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
comping in Pro tools LE - help requested! Plus great pro tools hd comping tip! | mr xy | Tips & Tricks | 10 | 10-10-2009 03:12 PM |
PT LE 7.1 Reason delay, can't record?? | Matdude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-03-2007 08:16 AM |
Reason Problem: Distorting/Delay | Seventh Factor | Pro Tools TDM Systems (Mac) | 0 | 07-19-2003 02:50 PM |
***mbox, reason, koblo, and plaback delay*** | joelsimone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-19-2002 06:46 PM |
Reason Iac bus delay | keysmia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-10-2002 06:47 AM |
