Why can\'t you increase the system memory?
Why can't you increase the system memory allocated to the DAE playback buffer? I have like 3 gigs, it doesn't increase past 115mb.
I'd like to have a higher level at higher track counts. 96 Tracks, 96k, level 4 needs like 300+mb but there's no way I can increase the memory allocated past 115mb, even though there's 3 gig's in the comp. Bobby Peru Milwaukee, WI
Shane Olivo Bobby Peru Recording The New Loud Milwaukee, WI Check out my studio :) http://www.bobbyperurecording.com Check out my band :) http://www.newloud.com |
Re: Why can\'t you increase the system memory?
Under a true multitasking OS like OS X memory is dynamically allocated to the application as it's required.. simply allocating a shared resource to an application when it doesn't require it would be wasteful -- a well behaved application will request (allocate) memory when it needs it and return (deallocate) memory when it's done with it dynamically.
If you change the playback engine and Pro Tools needs more RAM it'll prompt you to restart the Mac. Rail
Memory increase | skabuddah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-10-2010 07:05 AM |
Question about memory increase. | Greene | Pro Tools TDM Systems (Mac) | 0 | 01-25-2008 12:28 PM |
Playback Engine - how do you increase system memory? | dopplah | Pro Tools TDM Systems (Win) | 2 | 08-24-2007 02:25 PM |
Increase memory allocation | Critical Bill | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-16-2004 09:45 PM |
Increase drive capacity w/PTIII TDM system | BBPS | Storage Subsystems | 1 | 06-12-2003 06:46 PM |
