Old 01-02-2010, 02:19 AM
imloggedin imloggedin is offline
Default 8.0.3 = Tons of Static
Windows XP
192 I/O
Just installed 8.0.3, because 8.0.1 was having funky CPU issues on a large session. Now all of my audio tracks in every session randomly have massive amounts (over 0db) of static scrolling through every channel. I deleted pref's and everything and its still happening. If I mute all the channels it still happens but you dont hear it (u see it). WOW. Really crappy. Now I get to spend hours trying to figure it out when I have a session to complete.
.....At a stand still. Any ideas?
Old 01-02-2010, 06:41 AM
Default Re: 8.0.3 = Tons of Static
Can you back up to the previous version so you can finish your project?
Old 01-06-2010, 08:04 AM
stevefaris stevefaris is offline
I was having the same problem with my laptop only. My desktop worked fine.
After doing some reading, I found out that PT requires a 7200 RPM or faster hard drive.
After upgrading my drive, I no longer had any static. All the playback errors I was reveiving went away.
Check your drive spec's. Maybe this will fix your issues as well.
Good luck.
Old 01-27-2010, 02:29 PM
Still havent been able to fix this. Downgraded back to 8.0.1. Still doing it, I cant risk deleteing all my plugins and trying again. Thanks for screwing me digi! Spend lots of money and get worthless updates.
Old 01-27-2010, 03:59 PM
bishop81 bishop81 is offline
digidesign is currently working on this..if I knew how to post a link to the thread I would...if you search under 'white noise or static' you should find it.
still having the same issue but I havn't replied to themn yet.
new at this stuff so I hope that helped
Old 01-27-2010, 07:51 PM
Kris75's Avatar
Kris75 Kris75 is offline
Space Cabin Audio
In order to go back to 8.01, you will have to go back to a previous image (I hope you have one) or you will have to reinstall your OS. 8.03 does something that can not be undone just by uninstalling PT. Sorry to be the bearer of bad news.
You can read more about the MANY people experiencing this here
http://duc.digidesign.com/showthread.php?t=264148
Sign up for all things....AWESOME!
Kris
May the music move you
Old 01-27-2010, 07:59 PM
necjamc necjamc is offline
This may or may not help but I was having this problem and I went nuts for 2 weeks trying to fix it. Here's what I did:
Searched here!
searched M-audio (I use a profire 2626 with M-Powered)
did a support email to digi, several emails back but didn't have any real info other than the usual read this check that.
THEN........
I was using a wd caviar black 7200RPM 320 gig internal HDD, sata
and also every now and then a eSATA with a wd caviar black 7200RPM 1TB drive in it.
Believe it or not when I took the drive off of eSATA and mounted it internal all the static problems went away
Like I said it's my story and i'm sticking to it.
But you should try sessions on different drives. Take good sessions and copy them to your reg drive and try to recreate it, that's how I found out it was the eSATA controller.
That's My 84 cents
Old 01-28-2010, 01:08 AM
TOM@METRO's Avatar
I know this is not believable but, part of the path to stabilize this system was a WD Black for the system drive.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 01-28-2010, 01:56 AM
Kris75's Avatar
Space Cabin Audio
Digi,
Is there a way we can consoldate all of these White Noise Burst posts into a common thread where we can all try and figure it out? At the moment they are scattered all over the DUC.
Kris
Old 01-28-2010, 07:23 AM
My problem wasn'treally the drive more the esata controller I think although my wd drives seem to take extra time to analyze audio after each recorded pass.
Plug-Ins using tons of CPU RichrdC Pro Tools M-Powered (Win) 0 08-27-2009 04:26 PM
Amplitube Using Tons of CPU RichrdC Pro Tools M-Powered (Win) 11 08-16-2009 07:53 PM
Tons and Tons of Outboard Gear TommyComa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 06-18-2007 11:43 AM
6.9 using up TONS of CPU Produce_Dept 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 04-25-2005 06:48 AM
tons of questions for you all fuelie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-26-2002 02:22 PM
