Old 10-16-2018, 11:50 AM
sjgam sjgam is offline
Default Recommended ethernet switch for Artist and Dock Connection
Just got the Mix and just ordered the Dock - is there a standard, reliable ethernet switch to connect these units to my Mac you would recommend. I will only use it for connecting these units.
Old 10-17-2018, 12:07 PM
home_studio home_studio is offline
Default Re: Recommended ethernet switch for Artist and Dock Connection
I hope I understood you correctly.
Any 1gb router will do.
2023.12 Ultimate / Mac Pro (Late 2013) / 6 core 3.5GHz / 64Gb / OSX 12.7.2 / MTRX Studio / 2xArtist Mix / PT|Control / Aja T-Tap
Old 10-17-2018, 07:56 PM
EddieJones's Avatar
A router is different from a switch. A 1GB switch would do also and may be cheaper.
Old 10-19-2018, 04:50 AM
Thanks for guidance - one 1gb switch (D-Link because it is small) is on its way.
Question - my iPad with Control app currently on its own with no Dock works without WiFi and iPad is powered by just connecting lightning cable to USB port on my MacBook Pro running Logic. Apparently the usb lightning cable is doing data and power.
So it does not seem necessary to get the camera kit and Ethernet adaptor for iPad or use WiFi when I get my Dock- am I missing something?
Old 10-19-2018, 08:10 AM
EddieJones's Avatar
If its working then thats OK, it should continue once you connect the other surfaces.
Old 10-19-2018, 09:09 AM
Ok I will confirm once I receive and install the Dock on Monday.
But are you surprised that iPad Control works with straight lightening to usb on Mac and no Wifi or ethernet? I see nothing about this in the manual - just wifi or ethernet adaptor/camera kit recommendation.
Web/Dock/Control all (3) on Ethernet - no switch reichman Avid S1, S3, Dock and Control App 0 02-22-2017 10:32 AM
Recommended USB>Ethernet for MC Mix oortone Artist Series 7 08-27-2015 01:41 AM
Help Avid Artist Control losing connection with logic X using usb to ethernet adapter smartinez5878 Artist Series 4 06-23-2014 11:10 PM
Artist Control / Ethernet Connection and Noise Problems lberrios1962 Artist Series 8 05-04-2012 08:20 AM
10-BaseT Ethernet Hub - Which Most Highly Recommended?? Curve Dominant ICON & C|24 3 05-13-2007 08:25 AM
