Old 08-30-2012, 02:35 PM
phatbeatstudio phatbeatstudio is offline
Default Is there a way to undo plugin adjustments just like everything else.
Sometimes I find myself getting a little to creative on EQ but would like to undo it to a point where I liked it better.
Thanks HAVE A NICE DAY
Old 08-30-2012, 02:47 PM
jasonthurley's Avatar
jasonthurley jasonthurley is offline
Default Re: Is there a way to undo plugin adjustments just like everything else.
Wouldn't that be nice??!!
Only way I know of is to open a session backup and then save the preset in the Plug... then recall it in your main session.
Old 08-30-2012, 02:51 PM
Dism Dism is offline
Save As... is your friend.
If you decided to get experimental, just save a new session file. If you don't like it, open the older session file.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 08-30-2012, 03:10 PM
elicious elicious is offline
or just use the a>b function in many plugs
or the compare button.
e
ihatetyping
Old 08-30-2012, 10:42 PM
meech meech is offline
Unfortunately undo/redo isn't possible with plugins.
I use a combination of command+shift+c and command+shift+v, also save as... making a temporary copy of a plugin, and also duplicating an entire track if I want to experiment.
Ideally I think it would be great if a DAW could keep two separate undo histories/sequences for edit and mix/plugin functions. Imagine if command z and command shift z undid/redid edits, and adding option to those commands undid volume, pan, plugin parameters, etc...
HD Native - Apogee Symphony I/O
Mac Pro 6 core 3.33 Westmere 16 GB of RAM
PTHD 10.2
OSX 10.7.5
Old 08-31-2012, 12:47 AM
Meads Meads is offline
That's why you have to love Waves plugins. They all have an undo-function implemented.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 08-31-2012, 02:44 AM
To simply reset any parameter, you can Alt-click on it(Option-click for Mac?). That trick will default almost any knob
Old 08-31-2012, 11:00 AM
mbourque mbourque is offline
You can also save the settings as a preset before doing to much modifications. This way, you can switch easely from multiple versions of the tweaks you've done.
Matthieu Bourque
PT Ultimate 2022.10 on macOS 12.6.1
Old 08-31-2012, 12:28 PM
Stig Eliassen's Avatar
Import plugin settings from one of the backup session files with Import Session Data.
Old 08-31-2012, 04:17 PM
Bill Denton Bill Denton is offline
+1 on that...I had the same idea when I read the original post, but I was at work and I can't post anything from there...
And phatbeatstudio, given all the problems you've had, why don't you name each preset something like "2012-08-31 7-17PM" so you can keep track of them...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Fader Adjustments digi003 Pro Tools 10 6 12-09-2011 04:34 PM
DTS: No 'Q' adjustments on EQ3 w/MC Control postprosound Artist Series 1 12-17-2010 09:14 AM
Tab to transient adjustments? broken81 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-15-2009 09:39 PM
keep the fader UNDO and edits UNDO separate uno1234 Pro Tools TDM Systems (Mac) 5 12-06-2005 09:30 AM
I can't undo record audio, I CANT UNDO !!! Dither16bit Digidesign Hardware & Software 0 06-09-2004 01:53 AM
