Old 06-25-2019, 02:08 AM
bobo mark bobo mark is offline
Default Mojava 10.14.5 Compatiablity of Eucontrol 2019.5.1
Hi:
after i installed the Eucontrol 2019.5.1 i cannot assign Eucontrol in Security and Privacy Accessibility tab.
any help??
Regards
Bobo
Old 06-25-2019, 02:21 AM
xrekcor's Avatar
xrekcor xrekcor is offline
Default Re: Mojava 10.14.5 Compatiablity of Eucontrol 2019.5.1
Originally Posted by bobo mark View Post
Hi:
any help??
not a lot of info there, but try this...
It's in Security&Privarcy>Privarcy tab. If at Accessibility and you cant select it or its not highlight there is a little "Padlock" icon in the lower left click on it to unlock the settings to be changed.
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
Old 06-25-2019, 03:20 AM
I already manuelly to change setting but nothing happen..
Regards
Bobo
Old 06-25-2019, 03:39 AM
xrekcor's Avatar
that doesn't tell us very much.
are you able to give us more information of what's going on? like what control surface are you connecting to is WiFi connected/working at both ends, the steps you have taken to get this working, is EuControl app working and present on the task bar.... may be others may need to chime in.
Rob
Old 06-25-2019, 05:29 AM
Here is the detail:
Mac Pro 2013 12core 1TB/64GB running on Mojave 10.14.5.
After i install Eucon 2019.5.1 it request me to assign Eucon software in Security and Privacy Accessibility tab .
As i use + sign to select /application/Eucontrol. the tab has nothing happen. so i cant assing Eucon in Security Privacy Accessibility at all.
so that mean Encontrol cannot be launch at all
I have exactly same Mac running in next room with High Sierra without single problem. running Eucon via ethernet on Avid Dock and Ipad Control.
I am thinking this is only happen on 10.14.5.. I search DUC no one complain it before .
Regards
Bobo
2019 Gui Lag manfromspace Pro Tools 2019 7 06-20-2019 01:59 AM
2019.8 amagras Pro Tools 2019 89 06-10-2019 12:40 AM
EuControl 2019.5??? Akiz Pro Tools 2019 6 05-09-2019 01:34 PM
