Routing output of master fader
I unfortunately broke my headphone jack on my 002 and figured I could route the output from my master fader to a seperate amp for my headphones. When I assigned the output to outputs 7 and 8 I get no signal.I assigned the output from an individual audio track and it worked, so I know the connection is working. What am I missing?
Thanks, Marty |
Re: Routing output of master fader
Did you select the alt/syn to monitor button next to the monitor level control?
The Master output fader isn't an assignment.. it signifies which output the fader is controlling. By definition, a master fader is the final master output for the defined output. What you want to do is instead of using Outputs 1&2 as your mix buss.. create a stereo Aux track, assign the inputs to an unused stereo buss pair (say Busses 1&2) -- assign the outputs of the Aux track to Output 1&2 and while holding down the Control key on the Mac.. also assign it to any other outputs.. in this case Outputs 7&8. For your mix tracks, assign them all to the same Buss pair you selected for your Aux track input.. in this example Busses 1&2.
Rail
Thank You,
Marty |
Master fader final output level | bryced87 | macOS | 5 | 04-22-2013 05:10 AM |
master fader output w/ headphones one | willl3 | Pro Tools HDX & HD Native Systems (Win) | 1 | 12-29-2012 06:42 AM |
trouble routing to master fader | radioinactive | Pro Tools TDM Systems (Mac) | 15 | 11-02-2010 11:35 AM |
Routing around the Master Fader | 2hip2b4real | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-05-2008 11:25 AM |
No output to 1622 *and* master fader shows output? | nettwerk | Pro Tools TDM Systems (Mac) | 1 | 10-30-2000 05:35 AM |
