Old 08-02-2001, 08:53 AM
lewis lewis is offline
Default "access denied" when using audio suite plugs
RTAS work fine.any ideas?
Old 08-02-2001, 09:13 PM
Don M Don M is offline
Default Re: "access denied" when using audio suite plugs
This happens when you restore a project from a CD rom back up due to the files being marked as "read only". Just go to the audio files folder and highlight all files, right click on "properties" and uncheck read only. That should fix it.
Old 08-02-2001, 10:00 PM
ReniuR ReniuR is offline
you can also right click on the main session folder, choose properties, and uncheck read only. If you do it on a folder, it asks you if you want that change to apply only to that directory, or all the files in the directory. Choose all files, and it's done.
If you select all the files themselves and right ckick to choose properties, it will most likely open a seperate properties window for each file you selected, making you change every file property one at a time.
[ August 02, 2001: Message edited by: ReniuR ]
-ReniuR
www.disposableproductions.com
Old 08-02-2001, 10:25 PM
The files did come from a cd-r,and "read only" was already unchecked.I also de-fragged drives,which did no good. [img]images/icons/confused.gif[/img]
Old 08-02-2001, 11:18 PM
Dreamware Dreamware is offline
Sometimes the DAE preferences get corrupted. All you have to do is go into the preferences folder and delete whatever is in there and reboot.
Regards,
Alex T.
Alex
www.dreamware.ca
Have something to brag about...Own a Dreamware Audio PC...
My Rig:
AMD Athlon XP 1700+
512MB PC2700C2 Corsair
MSI KT3ULTRA ARU
2x 80GB Seagate Barracuda 4 in RAID 0
GeForce 2 Ti 64MB
Lite-On 40x12x40 CD-RW
16x Pioneer DVD
Intel Pro/100 +
SB Audigy
Digi 001
Old 08-02-2001, 11:53 PM
Um,delete what?It doesn't seem to give me the option.I don't know whether this makes much difference,but it also says "access violation occured".
Old 08-03-2001, 12:10 AM
I found the folder you were talking about and deleted it's contents,rebooted,and nothings changed. [img]images/icons/frown.gif[/img]
Old 08-03-2001, 12:28 AM
Since there could be so many variables regarding your problem, sometimes dll files get corrupted. The best thing to do is re-install ptle. Remember to de-authorize any plug-ins you may have first.
Regards,
Alex T.
Alex
www.dreamware.ca
My Rig:
AMD Athlon XP 1700+
MSI KT3ULTRA ARU
GeForce 2 Ti 64MB
16x Pioneer DVD
Intel Pro/100 +
SB Audigy
Digi 001
Old 08-03-2001, 02:18 AM
thanks,I'll give it a try. [img]images/icons/smile.gif[/img]
Old 08-04-2001, 01:00 AM
I re-installed protools and the audiosuite still doesn't work.um? [img]images/icons/frown.gif[/img]
"Could not complete your request because Access is denied" ColinSound Windows 2 05-13-2013 02:58 PM
Audio Suite "No Audio Selected" to reverse clip ReynaldoPena Windows 1 11-24-2012 08:21 PM
"unable to parse audio file" and "OSStatus Error -208" ! reichman Post - Surround - Video 2 03-22-2010 04:46 AM
"access violation " protools can not make auto backup " nachonieto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-16-2008 03:54 PM
Audiosuite "Access denied" trey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-07-2002 08:20 PM
