Old 03-07-2002, 01:04 PM
trey trey is offline
Default Audiosuite "Access denied"
Everytime I try process (edit) and audio track,with any of the audiosuite plugins I get the access denied message. It works fine as a plug in. I have to "save copy as" and then open the new file in order to process the track. Is this normal?? If not, how do i fix it. The manual hasn't helped.
Thanx for your help [img]images/icons/confused.gif[/img] [email protected]
Old 03-07-2002, 01:26 PM
mlemos mlemos is offline
Default Re: Audiosuite "Access denied"
trey,
It sounds like some of your audio files have their file attribute set to 'read-only'.
You can manually check the read-only attribute for each file by right clicking on it, selecting properties and making sure that read-only is deselected.
You can also use a command prompt to deselect read-only from all of the files.
Just navigate to your audio files folder and type 'attrib *.* -r' without the quotes.
If you aren't very familiar with DOS I would do it manually though to avoid any problems.
Good luck,
Marc
Old 03-07-2002, 08:20 PM
Thank u Marc . U hit the nail on the head and I am, once again, a happy producer. [img]images/icons/grin.gif[/img]
"Could not complete your request because Access is denied" ColinSound Windows 2 05-13-2013 02:58 PM
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
"access violation " protools can not make auto backup " nachonieto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-16-2008 03:54 PM
"access denied" when using audio suite plugs lewis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 25 08-16-2001 12:52 AM
