Old 09-28-2023, 09:46 PM
TrentWilliams TrentWilliams is offline
Default PT23.9; Eucon Unstable & Buggy
Hey all,
Having a bit of a mare with Eucon and PT23.9, graphically track selection is freaking out and everything generally seems quite unstable.
Anyone else having issues? Curious if Eddy has a support update on the cards.
Link to what I've been working with below:
https://streamable.com/hwtfdy
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • Dock • Mac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
Old 09-28-2023, 11:36 PM
BScout BScout is offline
Default Re: PT23.9; Eucon Unstable & Buggy
What macOS version are you running? (looks like your signature is out of date)
If the macOS is correctly listed, you might want to upgrade it to macOS 11.7.10 instead of macOS 11.6.
(Also this looks like a Pro Tools issue and not a Eucon issue but it probably has to do with the macOS graphics engine which often is updated with point releases on macOS)
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3
Old 09-29-2023, 12:11 AM
DIRX DIRX is offline
I have a similar situation on 2 Win10 machines.
http://duc.avid.com/showthread.php?t=425854
Not as intense as in your Video,but quite like it, if I select a track in the timeline the colored borders flash about 2 to 3 times, then the flashing stops.
If I turn off the EUCON devices ( S1 and Dock an Ipad on one machine, or Artist Mix, Dock and Androit Tablets on the other machine ), ProTools shows normal behavior.
The "registry Eucon fix" did not change anything.
Old 09-29-2023, 12:14 AM
audiolex1 audiolex1 is offline
Current Eucon is 23.6.
Make sure you are on that version
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors
PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card.
OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW.
Almost every plugin
Old 09-29-2023, 12:38 AM
Thanks for the reply,
Sorry signature is quite out of date.
Running macOS 13.6; Eucon 23.6; PT23.9
Faders on my S3 are jumping around as the track selection is in that screen grab. All is well if I disable Eucon.
Old 09-29-2023, 12:41 AM
Displaying what tracks are selected on a control surface won't have much to do with Eucon. It's the same type of display (highlighted tracks) if you were running a HUI controller. The problem will be with Pro Tools and how it renders those graphics. But most of the time, these issues have to do with Pro Tools using some feature of the graphics framework that is only supported in later operating systems/drivers. On Macs, the driver only gets updated with macOS versions.
As for you, which exact version of Windows are you using? (Not just "Win 10" but is it the 22H2 version (release Oct 2022)?) There have been different frameworks in the different versions of Windows 10 and Pro Tools 2023.9 might be using one of those to render graphics.
Old 09-29-2023, 12:50 AM
That's more interesting as it shows a 2-way issue.
Have you hard power-cycled the S3 (pulled plug, wait a second, put plug back)?
Are you using a tablet (Control app) too or just the S3? If you are using the app, inside the app > settings > General, turn off "App Banks DAW" and see what happens.
Old 09-29-2023, 04:03 AM
Maybe I was not clear enough about the colored border flashing, it looks exactly like in TrentWilliams Video.
If I click in the timeline, which will select a track, the colored border around nearly all tracknames start to flash like a christmas tree for a short time.
In a normal situation it would show, that these tracks are "selected" via EUCON, because they are present on the control surface. The correct term for it is "controller focus border", as I see now in the manual.
Just one S1 connected is enough to show this flashing.
Win version on one of the machines is "Version 22H2 (OS Build 19045.3448)".
The other machine is out of reach for me today.
Old 10-01-2023, 12:20 AM
Following this patch-fix, Eucon is working a lot better, not perfect, but a lot better.
I must've missed this when it was posted.
https://duc.avid.com/showthread.php?t=425395&page=5
Track selection GUI no longer jumps around the window, but isn't accurately showing banked tracks.
Eucon 3.2.2 installer error + firmware downwards compatible with eucon 3.1 deauditievedienst Artist Series 2 07-14-2021 09:33 AM
ATTN: KYLE_S3/ Eucon 3.4 BUGGY bobbyguelz Avid S1, S3, Dock and Control App 2 07-24-2016 06:23 AM
EuCon suddenly broken - Eucon client can not access the bonjour service noiseboyuk Artist Series 0 04-12-2016 12:34 PM
iTunes 4 and Mbox are still a bit buggy (or I'm I buggy) Pat Thrall 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-24-2003 11:01 AM
