4 or 5k monitor
I'll be switching to a refurbished M1 next week (20 core, 48 core, 64Gb)
Do you have any recommendations for a cheap monitor. As a musician I don't need true colours or fancy graphic stuff. What do I have to pay attention to? I will be running M1 native (no rosetta). My idea was to use a thunderbolt port for the monitor because I want to connect a consumer TV for scoring movies to the HDMI port.
Mac Studio - Ventura- 64 Gb ram - SSD int 2T - SSD ext 4T - Antelope Galaxy 32 |
Re: 4 or 5k monitor
Pro Tools only supports up to 1080p, however, I run a 4K and it’s fine. At native resolution text can be hard to read but scaling is helpful.
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • Dock • Mac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W |
Re: 4 or 5k monitor
If you are using Mac OS, 5k is the way to go: The display scaling is the issue:
https://www.youtube.com/watch?v=5HZO-tfsQ-A
__________________________________ cMP 2 x 3,46, 128GB Ram Monterey 12.7.4 Metric Halo 3d 2882 I/O Lucid 88192 with Blue Sky 5.1 monitoring 10gbE ethernet with True Nas storage |
Re: 4 or 5k monitor
5K monitors are still more expensive and tougher to find, and there's essentially no advantage to their higher resolution at practical distances. It's only when you get unusually close or zoom in unnaturally that you'll see the extra resolution. My monitor is 2 or 3 feet away and my eyes can't detect any extra detail in 5K vs. 4K. I have settled on a 4K (a Dell) and it functions swimmingly. No performance issues. No lost detail. Works great with PT and games. I would suggest using a DisplayPort instead of HDMI -- with HDMI I experienced slight lag and it also wouldn't allow the monitor's maximum refresh rate. |
Re: 4 or 5k monitor
I have used LG monitors on Macs for a long while. One of my software development clients use them with the developers MacBook Pros, etc. after doing a comparison of different monitors. So LG is where I'd first look, and the current 27" lower priced options from them is:
https://www.amazon.com/LG-27BR750C-C.../dp/B0C64SBC8B https://www.lg.com/us/business/compu.../lg-27br750c-c I have not use that exact version but have used what it repalced. One comment is in the initial post the OP says "thunderbolt port". Just to be clear you don't need a Thunderbolt monitor. You need a compatible monitor, and that for more cost affordable current monitors will include monitors with USB-C connections that support DisplayPort over USB-C. As in the model above. The monitor specs should mention if they support Mac or at least mention DisplayPort aka "DP" over USB-C. You also have the option of using an Apple conversion dongle or one of many types of Thunderbolt or USB-C docks or hubs (but go Thunderbolt there) to add an additional HDMI connection. If saving cost is important I'd stick with 4K monitors. |
Re: 4 or 5k monitor
I’m using a Dell Ultrasharp 27 “4k” UHD. Scaling is good.
https://www.dell.com/en-us/shop/dell...or-accessories A 5k monitor isn’t cheap. Over a grand and closer to $1500 for something decent. Or more. What most manufacturers call 4k (4096x2160) are technically UHD (3840x2160) though for what we do the extra 256 horizontal pixels won’t matter. Figure $400-500 for a lower end UHD with a USB C hub. Mine was $700 or so. Thunderbolt video is simply Display Port down that wire. Any name brand UHD display with a USB-C video input will work with your Mac. Some will provide power down that port to be able to power/charge a laptop. I find that handy and also to use the USB hub as a dock. You’d likely be fine with an HD (1920x1080) for a couple hun. You likely won’t find one with USB C input that cheap (or at all) but you can get a DP dongle for $20-30 or so.
What happens in Vegas, we make happen... |
Re: 4 or 5k monitor
Have you considered a cost effective UltraWide monitor i.e. more pixels horizontally? If you are concerned with running Pro Tools which screen view do you use? If you mix in the arrange page they more tracks can been seen (vertically) so go for more pixels there. Personally I am old school and like to use the mixer view to mix! The extra real estate vertically might be largely wasted in a 4 or 5k monitor. For none Pro Tools use the ultra wide monitor is good with one window on the left and another on the right simultaneously. I am using a LG at 2560x1080 (UW-UXGA - Ultra Wide - Ultra Extended Graphics Array). It not perfect but is cost effective and does me fine. Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2 https://www.waves.com/r/djgsi6 |
Dual monitor vs single monitor setup | Whasssaaahhh | Pro Tools 9 | 23 | 03-17-2014 01:24 PM |
Can Studio Monitor Express & Transport act as digital monitor controller? | briancares | Artist Series | 1 | 02-04-2014 05:23 AM |
MBox 2 Pro Monitor knob has stopped changing monitor levels | Rumandolin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-21-2013 09:13 AM |
Pro Tools 10 / CPU Monitor low -> System Monitor high | mpeg5 | Pro Tools 10 | 0 | 12-09-2011 08:45 AM |
Dual Monitor / hardware playback with NTSC monitor | TheBriceShow | Post - Surround - Video | 2 | 02-21-2005 05:58 PM |
