Old 11-24-2021, 02:59 AM
vaggelis.mak vaggelis.mak is offline
Default M1, Pro Tools Compatibility
Hello, im currently using pro tools 2020.12 on MacBook Pro 2019. I just wanted to ask what is your experience with M1 chips and pro tools (especially after the latest update for m1 chips). And something else. is anyone have any experience with m1 pro and pro tools? I know its not compatible yet but some users were saying it work good.
Thanks
Old 11-24-2021, 03:24 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: M1, Pro Tools Compatibility
Currently, macOS Monterey is a disaster (and you absolutely must use it with these new pro/max chips) so you should wait. M1 mac mini and Big Sur however works much better.
Janne
Old 11-25-2021, 07:24 AM
JFreak's Avatar
Hi, welcome to the community.
As I said, avoid Monterey for now, at all costs. I will be happy to report once my problems are gone.
Janne
Old 11-25-2021, 08:55 AM
Drew Mazurek's Avatar
I just got a 16" M1 Max and Monterey is better here than BS for sure.
What makes you say "disaster"?
www.drewmazurek.com
Old 11-25-2021, 08:58 AM
JFreak's Avatar
Severe memory leaks, at least on 12.0.1 release. Don't know if you have a newer one but this install of mine resembles Windows95 as in need to reboot every day, and software randomly jamming because of the memory leaks.
Janne
Old 11-25-2021, 09:05 AM
JFreak's Avatar
Had to tapatalk the previous, because Safari suddenly ate 12 gigs of memory (out of 16 gigs). That is how bad it is.
Janne
I'm on the 12.1 BETA. How do I check this?
Everything is running great here.
www.drewmazurek.com
Old 11-25-2021, 09:06 AM
JFreak's Avatar
Keep the activity monitor open, with memory tab sorted to memory used. You should know when things go south.
Janne
Old 11-25-2021, 09:16 AM
Nothing unusual happening. Been on it all morning.
www.drewmazurek.com
Old 11-25-2021, 09:18 AM
JFreak's Avatar
Keep it going without rebooting. I have been used to uptime between dot releases, not every day. And I do not even necessarily do every dot update so uptime is easily three digit days
Janne
Recommended iMac Specs for Pro Tools 2021.3 (Pro Tools STANDARD) BigSur Compatibility Spoil the Child macOS 19 04-05-2021 05:35 PM
Pro Tools First vs. Regular Pro Tools Hardware Compatibility Tanis Pro Tools | Intro Discussion 4 04-02-2020 04:05 PM
Pro Tools 12 compatibility recorpro Pro Tools 12 3 12-06-2017 12:26 AM
Pro Tools Compatibility psyd Getting Started 0 08-01-2017 07:46 PM
M-Box to Pro Tools TDM / HD compatibility ? SportsSounds Post - Surround - Video 1 12-17-2003 08:15 AM
