Pre-Fader-Send and Pre-Plug-In routing
We´re assuming (and it sounds just like that) that if switching the send pre-fader, we also switch it pre-plug-ins? Is that correct?
Re: Pre-Fader-Send and Pre-Plug-In routing
Nope, sends are always post-insert. If you want to send something pre-insert then you'll have to put a send on the track and then output the track to a bus, then put the inserts on an AUX that has its input set to that bus.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
If I want to have a pre-plugin send, you can either do what Mesaone suggested with an aux track; or just duplicate the original track remove the plugins and use that as your send track.
You can also set the output of the duplicate track to a bus if you don't need the unprocessed signal coming through your main bus. |
Routing send fader to PC | Dopamine | ProControl, Control|24, Command|8 | 2 | 10-15-2009 03:44 PM |
Routing Reverb to Cue Send? | rwhitney | Tips & Tricks | 4 | 05-22-2007 08:08 PM |
5.0 aux send/return : routing clarification please | Aquarius | Post - Surround - Video | 9 | 06-27-2006 10:21 PM |
Can you copy send routing? | McMasters | Tips & Tricks | 6 | 06-08-2002 06:40 AM |
Question re: FX send routing | Dopamine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-22-2001 12:05 AM |
