Pro Tools can't create a new session
Anybody experience this before? I tried upgrading from Pro Tools 11.1.2 to 11.1.3, and still had the same problems. Any help or suggestions much appreciated.
Could not create a new document because Assertion in "/Volumes/Development/126373/ProTools/DFW/MacBuild/../Views/UMenu.MacOS.mm", line 1547. Pro Tools 11.1.3 Apogee Duet for iPad and Mac Macbook Pro 2.3 Ghz Intel Core i7 16 GB 1600 MHz DDR3 RAM Graphics NVIDIA GeForce GT 750M 2048 MB OSX 10.9.2 500 GB Flash Storage Lacie External 1 TB Firewire Disk used with Firewire 800 to Thunderboldt Adapter Novation 61SL MKII Keith Mcmillen Qunexus Novation Launchpad Mini Korg PadKontrol Belkin USB HUb Secondary Display through HDMI Port-DX19LD150A11 Display |
Re: Pro Tools can't create a new session
Yes, we have been dealing with Assertion Errors for 10 years
I'd start with the Database and Catalog files
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Have you tried creating a new session from your internal drive? I assume you've been using the LaCie external! Is it the same starting new session on both internal and external drives. Does the drive/ partition / folder path have any illegal characters? Like.. @/#/& /$ same goes for the session title does it have any illegal characters or is the title or file oath unusually long? Chris
Unfortunately I still can't even open the program. I can't open or create any session at all from the internal drive or the external drive. I tried moving the ilok to a different port. I tried unplugging the Duet. I also tried manually uninstalling Pro Tools, then reinstalling. Nothing seems to be working. I couldn't find the Database or Catalog ties to delete.
Thanks for the tips. any other thoughts about this? |
go to post 44 and it's in his sig file. As a trial uninstall the Duet (s/w and h/w) and try running off your computer's built-in audio. It won't be pretty but if it works you'll know that at least a barebones system is working. |
Thanks, I'll give it a try.
Much appreciated. |
Musicman691,
thank you so much. The program to trash the preferences worked the first time, right out of the gate. I'm back up and running and I didn't even need to do the uninstall/reinstall for the Apogee software or hardware. In fact, Pro Tools immediately recognized the Duet as the I/O. Thanks again |
Pro Tools 9 won't open or create a new session | G-Lay | macOS | 9 | 05-09-2011 04:48 PM |
Protools M-Powered quits session when trying to create a new session on my MacBookPro | Edavis229 | Pro Tools M-Powered (Mac) | 1 | 04-05-2011 02:33 PM |
Pro tools 7.1.2 wont create session at 48 KHZ | cinetj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-20-2009 02:40 AM |
How...Create New session with Session Template | TDelmar | Tips & Tricks | 5 | 10-22-2008 08:29 PM |
How to create a default pro tools session file? | OTL | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-25-2008 07:52 PM |
