Old 02-24-2012, 08:15 AM
jj5000 jj5000 is offline
Default Installing PT 10 - Should I uninstall 9 or
Installing PT 10 - Should I uninstall 9 or just run the installer over 9.
I know a fresh install is always better, just wondering if there are any serious issues.
Thanks.
Old 02-24-2012, 04:19 PM
cheekypaul cheekypaul is offline
Default Re: Installing PT 10 - Should I uninstall 9 or
installing 10 deletes 9... does it?
Mac Computers/PT12/Lots Of Lacie D2s
Old 02-24-2012, 05:18 PM
Okay, that sounds good.
Just maybie a quick fix of the mac permissions after the install (or before?)
I'm assuming all the old plug-ins either roll over or get updated?
Old 02-25-2012, 12:49 AM
What's your set up? Operating system etc. Are all your plugs up to date?
Old 02-25-2012, 08:01 AM
nst7 nst7 is offline
It only takes about 2 minutes to do a complete (clean) uninstall of Protools. I recommend that, as you're less likely to have problems.
It's also a good idea to repair disk permissions after uninstalling, and after installing 10.
Old 02-25-2012, 06:29 PM
Dave Lang Dave Lang is offline
+1 for doing a complete uninstall of 9 before installing 10. I'd even do a reboot. If you read through the problem posts from around the time when 10 was first released you'll see lots of situations where installing 10 with 9 already installed caused trouble.
Uninstall PT Before installing 10.3.3 RCN Pro Tools TDM Systems (Mac) 10 12-28-2012 07:50 PM
what uninstall before PT 10 installing flautista Pro Tools 10 5 12-11-2011 06:12 AM
Uninstall 8.04 before installing PT9? xpandnz Windows 1 01-31-2011 11:54 PM
Uninstall 7.3 before Installing 7.4? GuyPicks Pro Tools TDM Systems (Mac) 2 01-11-2008 06:42 PM
Uninstall 6.4 before installing 6.7? neonknight 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 24 11-10-2004 01:42 PM
