Old 07-11-2011, 08:31 PM
drumzalicious drumzalicious is offline
Default Would I really notice a difference with more RAM?
Hey guys. Currently I'm using a
MacBook Pro 13"
Processor Name: Intel Core 2 Duo
Processor Speed: 2.4 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 3 MB
Memory: 4 GB
Bus Speed: 1.07 GHz
Recording to an OWC 250 GB AL Pro Drive.
Setup is MBP>MBox2Pro>Ext HD
I hear conflicting reports all the time about whether or not Pro Tools will run better with 8GB of RAM vs 4 with it being a 32bit program. Can anyone give me any insight here
Old 07-12-2011, 03:10 AM
cheekypaul cheekypaul is offline
Default Re: Would I really notice a difference with more RAM?
as long as you're not running lots of other ram hungry programs at the same time as pro tools you're set up is not too bad as far as memory usage.
where ram really helps is when you have a plug in heavy session.
are you having problems?
Mac Computers/PT12/Lots Of Lacie D2s
Old 07-13-2011, 09:15 AM
No problems at all really. 50 track sessions on 256 hw buffer dae buffer set to default.
I was just more thinking if more RAM would give my computer an easier work load. Just thinking of ways to extend the life span of my computer down the road.
Old 07-13-2011, 10:19 AM
bradch00 bradch00 is offline
What year is your MBP? Some of the older (2008ish) core duo 2 will not recognize memory above 3GB, even though you can install 4GB RAM boards. However some people have reported using memory up to 8GB. YMMV.
http://support.apple.com/kb/HT2787
Pro Tools, Studio One Pro
2022 Mac Studio M1 Max 64GB-1TB NVME
OWC Thunderbay Mini (4TB SSD)
OWC Express 4M2 (4 X 2TB)
Interface: Presonus Quantum
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig)
Old 07-13-2011, 10:53 AM
sunburst79 sunburst79 is offline
Adding RAM is not going to make anything esier on the computer since the CPU is just doing math. Now if you were running out of memory or close to it adding memory would help prevent memory related errors
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 07-13-2011, 11:26 AM
Dism Dism is offline
2008ish?
More like, 2006ish.
My late 2007 MBP has 6GB running no problems, and even Apple spec'd it to go up to at least 4GB.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 07-13-2011, 12:45 PM
Park Seward's Avatar
Park Seward Park Seward is offline
With a 32 bit app like PT, you can't use any more than 4 GB of RAM. I understand the program actually uses less then 3 GB.
Of course if you have multiple apps running and a lot of VIs, then you could use more RAM in your computer.
You can open the Activity Utility and see exactly how much RAM a program is using.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 07-13-2011, 01:03 PM
Originally Posted by Dism View Post
2008ish?
Yeah, it's seems to be really unclear as to what the limitations are.
Old 07-14-2011, 03:38 PM
Its a mid 2010 mbp. It can go up to 8. Thanks for the feedback guys
would i notice a major difference between these 2 machines vudoo Pro Tools TDM Systems (Win) 2 04-20-2009 11:12 AM
Lucid GENx6-96..will I notice a difference.... psus15 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-11-2005 12:58 PM
24bit versus 16 bit. can you notice a difference? Alluvion 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-11-2004 01:11 AM
Anyone else notice... JMS40 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-03-2002 06:11 PM
JoeMeek VC3Q : Will I notice a difference vs Digi001? Kickin.da.speaker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 25 06-08-2002 10:24 AM
