Old 10-08-2009, 06:05 PM
MASTERLINKSTUDIOS MASTERLINKSTUDIOS is offline
Question Anyone using external SSD to record audio
Wondering because the prices are dropping and I see OWC with some with the right chipset.asking because I need a portable 7200 drive. Thanks in advance
Macpro 2.88-4 Gig Ram,HD2,Big Ben,Rosetta 200,Dangerous D Box,Mercury Bundle + Studio classics bundle ,C/24,2-UA 6176,U87ai,Genelec 8050 & 8020,Logic,Final Cut Studio 2,Canon hxa1(hd camera)-Macbook Pro,Mbox 2 Micro.http://www.masterlinkstudios.com/.http://www.myspace.com/masterlinkstudios
Old 10-09-2009, 08:10 AM
Default Re: Anyone using external SSD to record audio
Anyone????
Old 10-09-2009, 09:16 AM
JFreak's Avatar
JFreak JFreak is offline
SSD's are fast boot drives, but they're lousy data drives, because there's an infinite amount of write/rewrite cycles that it can handle. This was not a problem with USB memory sticks because they are rather slow, but for a fast throughput drive it's a problem.
I for one would not want to buy a drive I had to replace every 6 months or so...
Janne
Old 10-09-2009, 10:01 AM
FajitaTone FajitaTone is offline
Should be "FINITE"
Ray Trujillo
Freelance Audio Engineer
Old 10-09-2009, 11:49 AM
JFreak's Avatar
Originally Posted by FajitaTone View Post
Should be "FINITE"
Exactly. This just proves that my fingers are faster than my brain
Janne
Old 10-09-2009, 12:05 PM
Question Re: Anyone using external SSD to record audio
Thanks for the info. Never knew that ssd only could write or rewrite so many times. I'm gonna have to investigate. Thanks for any help everyone
Old 10-09-2009, 12:29 PM
Touchwood Studios Touchwood Studios is offline
I use a 2X250 GB OCZ Vertex SSDs in RAID 0 for my system drive Mac Pro Boots in about 30 secs and Protools boots in under 45 secs It''s killa fast
Old 10-09-2009, 12:54 PM
zodo zodo is offline
Modern SSD drives have a MTBF (mean time between failures) as good as or better than most consumer hard drives.
They have a real advantage in seek times for small files (virtually nonexistent). Read performance is generally excellent. Write performance is the major downfall, however. When an SSD has to write to an area that previously contained data, it has to go through two operations. First, it has to erase that block, which is an expensive operation time-wise. Second, it has to do the actual write operation. In effect, when the drive is brand new, you'll see amazing read AND write performance...until you've written to every block on the drive once, then you have to begin erasing before writing, causing a sudden performance drop-off. That kind of variation makes an unpredictable media drive. Unless you like inexplicable -9073 errors, I would stay away for now.
This anantech writeup will give you more information about it than you'll ever wish to know. =)
http://www.anandtech.com/storage/sho...spx?i=3531&p=8
Old 10-09-2009, 01:02 PM
What would be the benefit of connecting a super-fast SSD via a rather slow interface like FW800 or 400? Or are these housings eSATA you are talking about?
frank.
Old 10-09-2009, 06:22 PM
pgripp pgripp is offline
So an SSD would make a great sample library drive, correct? Ignoring the price per/GB.
Why does Avid recommend external USB over external Firewire for audio drive? DJ Hellfire Pro Tools 10 10 03-29-2012 09:39 PM
Backing up Audio Drive (External) and External HD Question JCWarrior Pro Tools TDM Systems (Mac) 2 04-13-2008 04:42 AM
external hard drive not an audio record volume tadeo2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 04-20-2005 11:49 PM
Can't record audio on external Lacie firewire driv zErOcOoL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-26-2004 01:47 PM
Can I record in stereo using the Powerbook G4 mini-jack external audio input? msa007 Digidesign Hardware & Software 2 01-26-2003 08:54 AM
