Old 08-18-2009, 10:58 AM
Edgur Edgur is offline
Default Automatic Delay Compensation not working like it should
We have recorded a piano track, and inserted a pitch shifter plugin that adjust pitch and timbre in real-time..... unfortunately it is delaying our track by just over 7000 samples. Now, the automatic delay compensation in the playback window has 3 settings: OFF, Short, and Long. I think short says 1024 samples and long says 4024 samples?? something like that. Anyways, we set it on LONG and the track was still very much off from the rest of the song. I don't understand......does LONG mean that the delay you are getting has to be around 4000 samples for it to work?? I've read in the pro Tools manual that setting this to ON (meaning setting it to short or long?) will compensate for all delay, but it doesn't say much more than that......and it doesn't seem to be compensating our delay of about 7000 samples. Will we have to fix this manually??
Thank you!!
Old 08-18-2009, 11:17 AM
blackmacdaddy blackmacdaddy is offline
Default Re: Automatic Delay Compensation not working like it should
Originally Posted by Edgur View Post
...about 7000 samples. Will we have to fix this manually??
Thank you!!
Yes, you'll move it back using the Option H command. I would either:
Duplicate the track & make a note that you shifted it in comments, Deactivate & Hide the original
OR
Make a duplicate playlist & make a note in the comments that you shifted it & by how much IE Moved -7000
Best!
W
It's only R'n'R but I like it.
Old 08-18-2009, 11:38 AM
mano111 mano111 is offline
Long is maximum 4095 samples. So 7000 is obviously too much for PT's ADC.
I recommend print the track (send to buss and record that buss to an audio track) then nudge the printed track -7000 samples then right click + hide and make inactive on the original track.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
Old 08-18-2009, 02:43 PM
Excellent! I will do that. Thank you.
Old 08-18-2009, 03:24 PM
crizdee's Avatar
crizdee crizdee is offline
whats your hardware buffer set to? you could lower the setting and reduce the latency on the track. it might be enough or do as suggested, move the track back and deactivate ADC on that track only. command control+ click on the adc number.
Producer, Engineer,
www.ukmastering.com
Old 08-18-2009, 03:56 PM
That brings up another question.....
I have got other tracks in the session that are delayed by about 100 samples or so.....those of which can be fixed by ADC. If I move my heavily delayed track so it fits, and keep the ADC on for the other tracks, will my track that I manually moved to the right spot be effected?? Can you apply ADC to certain tracks? If so how?
Thank you.
Old 08-18-2009, 07:50 PM
Also,
What are the pros and cons to using short ADC VS. Long ADC as far as saving processing resources....?? Why not just leave it on long if that is that max sample size that it will work?
Thanks Again!!
Old 08-19-2009, 02:10 AM
crizdee's Avatar
Thank you.
You only turn delay comp off for the tracks you move! that would be tracks with delay over 4095, the rest of the tracks that are under 4095 will be compensated for.
to turn the delay comp off on a track, you use "command+control+click" on the red number reading on the track you move.
Also,
Thanks Again!!
simply that! having it set to long uses more resources than short. so if you're short of DSP and using below 1000ms delay compensation then you can change it to short and re-gain some dsp on your cards.
Chris
Producer, Engineer,
www.ukmastering.com
Old 08-19-2009, 07:25 AM
Awesome! Thank you!
Problem with automatic delay compensation surstromming Pro Tools 11 17 10-29-2013 11:36 PM
Automatic Delay Compensation? Dax Xenos Pro Tools 9 15 06-06-2011 06:21 PM
Automatic Delay Compensation alfadog Pro Tools M-Powered (Win) 1 04-08-2006 07:53 PM
Automatic Delay Compensation stakeoutstudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-28-2005 01:02 PM
Automatic Delay Compensation slangification Pro Tools TDM Systems (Mac) 5 04-28-2004 11:02 AM
