Delay Compensation Has Stopped Working
HD3 Accel, Running PT 7.4 on OSX 10.4.9, G5 dual 2.7.
Delay Comp appears to have randomly stopped working in several sessions. Sessions where it clearly worked before, and where nothing has changed. I go to open the session, and there is red everywhere. Delay comp set to highest, etc. No other apps running. Literally nothing has changed, it just...stopped working on some tracks, really messing with the timing. I thought it was perhaps due to using the Fxpansion wrapper, but the red also shows up on tracks without it, using Soundtoys plugs, or others. It happens with aux sends as well as audio tracks. Any ideas or experience with this issue? |
Re: Delay Compensation Has Stopped Working
Most likely you have placed a large delay eating plugin on the mix-bus or you have changed your hardware buffer to a larger size. If you can take a screenshoot of your mix window and upload it to photobucket and paste the link here! i'm sure someone will identify the issue.
is that effective cuz i've been doing that to keep the numbers down
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
I'm an idiot. Dunno who changed the HW buffer, but that was it! Thanks Crizdee
You might need to keep it on for certain sync and time code reasons! but i doubt it? i can't think of a reason to have ADC on the master or mix bus Chris
i'm trying to get my feet wet with the ADC it does change things....sometimes in the most subtle ways good to know you are doing it like that....which is what barry rudolph told me to try and it is cool for me
What the hell is it now.. Delay Compensation not working on Midi? | makinghits | Windows | 13 | 01-07-2014 06:03 PM |
HD Native Delay Compensation not working! | nuancerec | Pro Tools HDX & HD Native Systems (Mac) | 10 | 01-24-2011 04:12 AM |
Delay Compensation Randomly Stops Working | edit machine | Pro Tools TDM Systems (Mac) | 6 | 11-02-2010 06:45 AM |
Automatic Delay Compensation not working like it should | Edgur | Pro Tools TDM Systems (Mac) | 8 | 08-19-2009 07:25 AM |
Delay compensation not working for RTAS plugs | dkesler | Pro Tools TDM Systems (Win) | 5 | 11-20-2007 08:41 AM |
