Re: Hardware Inserts - Bug If Using Main Out 1/2?
You 1/2 insert path is overlapping with your audition path. If you are going to use 1/2 for inserts, then take it out of the output path (monitor/audition).
Best practice is output/input page doesn't use anything you are using in inserts (delete or uncheck the box.)
But it's not when he uses 1-2 for inserts, it's when he uses other inserts and 1-2 as outputs....
Ahhhh a good old fashioned reset of PT Prefs has resolved all of the above issues...thankfully!
Sig |
Hardware insert 1&2 cutting off other hardware inserts on aux tracks | Led | Windows | 4 | 12-09-2013 09:19 AM |
Hardware Inserts | shootysurfy | Pro Tools TDM Systems (Mac) | 20 | 11-09-2009 11:18 AM |
Main outs(L&R) on 002R as inserts? | Gothboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-02-2008 01:32 PM |
Hardware Inserts on Main Stereo Out | Brimmy | ICON & C|24 | 1 | 10-04-2003 11:07 AM |
Hardware inserts | ssd | Pro Tools TDM Systems (Mac) | 3 | 11-20-2002 12:14 AM |
