Dual HD\'s - Can I back up PT files to System Drive?
I've got 2 hard drives in my G4. The system and protools is on one. I record sound files to the other. I've got plenty of space on the system drive. Can I back up/copy files to the system drive without affecting performance?
Thanks
One Mad Son The only difference between me and a madman is that I am not mad S. Dali |
Re: Dual HD\'s - Can I back up PT files to System Drive?
Yes
OneMadSon:
I've often backed up sessions on my system drive (as storage), and have never had a problem! However, it is recommended that you NOT actually RUN the session from the system drive; you should retransfer it back to the other drive to continue working the other drive, at a future date. I often backup sessions to the system disc when I'm unsure whether a client is truly "finished" and I want to access the files quickly; rather than committing to burning a Data-CD right away; then having to reload the CD. Incidentally, Toast has a great utility "Compare" program that checks whether your transfer between drives matches absolutely. I also have run the session on the system drive inadvertantly at times and had no problems. Opinions may vary on this topic - - O'll be interested in seeing what others say . . . Hope this helps. J Hilton |
Our G-4 came stock with an 80gb system drive, that is partitioned 20gb and 60gb. The 20gb partition is for applications and OS, the 60gb for back-up.
Hope this is helpful. |
Just a word of warning.
You can back up all your sessions/files/stuff to another drive. **just DO NOT run the session from the backed up location if things go wrong with the original session** If you do any recordings, the files will be stored on the _original_ drive as specified in the track/disk allocation setup in PT. This means that the new material you create will not be referenced by the session in the original folder. **So, if you do back up to another drive (on-line backup); make sure you RESTORE the session to the original location before you use it.**
_ _ _ _________ _ _ _ Murray |
can't restore system drive back up. | neuromillion | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 12-25-2010 08:08 PM |
Drive crashed! How to bring back SDII files ?? | Eduardo Luke | Pro Tools TDM Systems (Mac) | 2 | 08-31-2006 04:06 PM |
System drive back up with disk utility question | crizdee | Pro Tools TDM Systems (Mac) | 2 | 06-19-2005 01:58 AM |
Back up system folder on back up drive? | Mick F. Cantarella | Pro Tools TDM Systems (Mac) | 1 | 12-24-2002 09:15 AM |
OT: Proper back-up (system drive)... | soundboy69 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 11-26-2002 04:40 PM |
