Old 02-06-2012, 05:48 PM
Robsab Robsab is offline
Default Mega bug with Busses PT10.01
Hi
I just bump into a serious bug. Further than the 32 default busses, I have created 32 stereo and some mono busses in I/O. Have named them and assigned. Saved the session.
When I reopen the session most of the new busses are all wrong. IN the SENDS the busses are incorrect and in the AUX input tracks some have also its input incorrectly as well.
I fixed manually the busses several times and saved the sessions trying both enabling and not enabling "Sessions overwrite current I/O", but when the session reopens the problems always persist.
Anyone found a solution for this bug?
thanks!
Old 02-06-2012, 06:08 PM
Default Re: Mega bug with Busses PT10.01
Beside all the above problems, I have just noticed that Protools even allows me to create a new bus taking the name of an already existing bus. This is a nonsense. It should advise that this name is already taken by another bus!.
Old 02-06-2012, 06:38 PM
jjamesbomb jjamesbomb is offline
Default
There's def something weird going on right now w I/O assignment. Sometimes when I add a new track other ones stop playing and I have to reboot...
Old 02-06-2012, 11:41 PM
crizdee's Avatar
crizdee crizdee is offline
Originally Posted by Robsab View Post
Hi
thanks!
In the I/o setup page have you got a tick for... Session overwrites current I/o setup?
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-07-2012, 05:05 PM
DJ Hellfire DJ Hellfire is offline
Thumbs down Re: Mega bug with Busses PT10.01
Hi
thanks!
It's not 10.0.1. It's 10 period. I've had this problem since 10.0. Really aggravating.
Also, some times when I used "bus to new track", Pro Tools creates a new track with the new bus inactive and you can't make it active. The problem is Pro Tools assigns the new bus with a Mapped Output (which is confusing in itself) and you have to go into the i/o menu and uncheck the new bus' Mapped Output in order to make the bus active. I don't know why it does this but it pisses me off!
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
Old 02-07-2012, 05:09 PM
Originally Posted by crizdee View Post
Chris
Yes, I do!
Pro Tools 2021.12
Old 02-07-2012, 06:19 PM
Chris
Hi
Yes I did try several times but nothing got solved.
I found a workaround that for the time being is working. I just deleted from I/O "delete path" those busses that were causing problems (that actually were always the same). Then I created new ones with different names and problem solved.
I think the bug appears when most of the default busses are renamed and more busses are created in I/O, then the new Bus 1-2, bus 3-4 are mistaken by those original busses that have been renamed. At least is what the bug did to me.
Please AVID provide us with a fix for this.
Old 02-07-2012, 07:40 PM
NewdestinyX NewdestinyX is offline
+1. Totally frustrating bug! Agreed -- since 10.0.0 too. The whole 'mapping' a bus to an output thing is a huge mystery to me too. Does anyone know the underpinnings of why the bus window had to change to accommodate this functionality as of PT9 anyway? It worked PERFECTLY the old way. Busses were busses, Ins were Ins and Outs were outs. So simple... oy... *sigh*
Rig 1-Mix/Mast: PTHD 11.3.1; MacPro 6core (6,1) 3.5 GHz Xeon E5; 10.10.3 (SSD Drives for audio); Apogee DUET, FireStudio2626 as Hware Inserts to PT for outboard
Rig 2-Cutting&Remotes: PTHD 11.3.1; MacBook Pro (8,1) 2.8 GHz Dual i7; 10.9.2 (128GB int '6G' SSD drive); Profire LightBridge (FW800), 32ch Presonus Digimax FS
Old 02-07-2012, 09:24 PM
gives's Avatar
gives gives is offline
Hi
YUP.. I think that is when I have had problems too! I am going back to the old "Standard" bus names. G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
Old 02-08-2012, 12:58 AM
thierryd thierryd is offline
FWIW it wasn't "perfect" either before PT9. The changes were introduced in PT9 for the new interfaces (suchs as Omni) and they do make sense (plus there was the benefit that the busses went up from 128 to 256 which was a much needed change). Also it's good that PT searches for free buss paths by itself, compared to the old way.
The unfortunate thing is that it is still buggy. Basically I don't thrust things that PT does "automatically". I don't use ADC, nor DSP cache because of this. The new I/O structure can't be bypassed so I learned to work around the buggy behavior which basically means that you should build the session or template till it has everything you need (busses, tracks, sends etc.) and then quit PT and restart. I found that with PT10 adding tracks or changing the I/O while mixing, will almost guarantee a crash sometime after the change. If you don't change the structure of the PT session, PT will be fairly stable. This is especially so if you work agains the dsp and native limits of the system (which I do a lot)
Greetings,
Thierry
http://www.a-sound.com/
mono busses use Surround ADC (DSP) in PT10. Didn't in 9 made macOS 0 01-19-2012 05:22 AM
mega phone plugin harryk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-02-2008 01:23 PM
Need Loooooooong mega mix ,..any suggestions Badooker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-26-2002 03:15 PM
New mega mixfarm coming loopengine General Discussion 10 12-16-2000 04:41 AM
Megaverb = Mega Pops Grey Pro Tools TDM Systems (Mac) 2 02-23-2000 07:23 AM
