Old 12-12-2010, 07:09 PM
GanB GanB is offline
Question Eleven Rack Not Showing Up In PT9
Argh! I've been browsing the forum and can't seem to find any solution to this problem.
I upgraded from PT LE 8.0.4 to PT 9 on Windows 7 Enterprise 64 bit. I am running Eleven Rack Firmware 1.0.3 Build 0.6.2.0. My rig was just fine before I moved to PT 9 and now I cannot see my 11 Rack in the hardware list. I also cannot see it as a valid input/output in my tracks.
My 11R is clearly visible to the rest of Windows, as I'm able to use my Kontakt 4 Software with it and I can see the interface for it in the Windows Control Panel. PT is just not seeing it.
Any suggestions??
Old 12-12-2010, 07:13 PM
Default Re: Eleven Rack Not Showing Up In PT9
Windows 7 Enterprise is not a recommended Pro Tools 9.0 System Requirement.
Aaron Mulqueen - 001 HD Native
Old 12-12-2010, 07:24 PM
Ok, I got a resolution! Apparrently, you have to switch the playback engine under the setup options to 11R FIRST and THEN you can see it in the list of hardware devices. Once I made the change in that order, everything seems to be just fine
Old 12-12-2010, 07:39 PM
Just curious, what other devices are listed in the Playback Engine dialog?
Old 12-12-2010, 07:46 PM
Eleven Rack
Creative Asio
Guitar Rig Session I/O
Rig Kontrol 3
SB Audigy 4
Old 12-12-2010, 07:52 PM
Good o.
Old 12-12-2010, 08:01 PM
Yeah I appear to be good to go except my Structure Plugin seems to be gone and now I only see Structure Free. Why is everything such a hassle with this?
Old 12-12-2010, 08:03 PM
Structure needs to be reinstalled.
Eleven Rack not showing up in Pro Tools LE jazz4man Eleven Rack 20 11-22-2013 10:55 PM
Eleven Rack not showing in Pro Tools hardware list Mack Truck Pro Tools 10 1 09-06-2012 03:13 AM
Eleven Rack not showing under hardware or playback AdamAMM macOS 5 10-24-2011 03:27 PM
Eleven Rack not showing as input mac PT9? microstudio Eleven Rack 6 03-15-2011 09:15 PM
Eleven Rack window not showing. 8.0.3cs1 Venture Studios Pro Tools TDM Systems (Win) 3 03-08-2010 02:02 PM
