Old 01-08-2010, 10:32 AM
sunburst79 sunburst79 is offline
Default Re: Problem using 3 card system in a mixture of PCI-x and PCI slots
BTW I just checked with Bob and he said his slots were set at 133Mhz....So it looks like I may be wrong on the speed thing. Although he was only running 2 cards and both in the PCI-X slots. It may be when you mix slot types you need to lower the bus speed. All I'm really suggesting is trying another PCI-X speed if 133 isnt working.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 01-08-2010, 11:08 AM
DigitalMetal DigitalMetal is offline
Im very interested to know if anyone has any concrete figures for how much pci bandwidth a PTHD card actually needs,
Then we can see how much bandwidth a slot or a PCI bus has available & know whether there is a bottleneck somewhere,
This may be the cause of not being able to add a 3rd card in the supermicro board and why i struggled with my Gigabyte board that x9blade has.
If my expansion chassis and the single PCIX slot that it is plugged into has enough bandwidth to run my 3 cards without problems then it must be under the quoted figures i posted previously.
x9blade i dont really track with my system i mainly import and mix with it but i dont really have any latency to speak of, i usually run my buffer size at 512 even when maxing out 3 cards with plugins while mixing.
PT10HD5 PCIX in 64Bit Magma Chassis,
2x192io's + 2x96io's & Legacy io's
Pro Control & Fader Pack
UAD2 Quad, Octo & All Plugins
Black Lion Audio Modified MOTU 24io and 2408MK3 x2
TC Powercore PCI MK2 x2 & Firewire
Softube, Sonnox, Eventide, SSL, McDSP, Waves
Old 01-08-2010, 11:23 AM
If my expansion chassis and the single PCI-X slot that it is plugged into has enough bandwidth to run my 3 cards without problems then it must be under the quoted figures i posted previously.
You would have to go find a block drawing of the chipset but as I recall the PCI-X lanes on the old 975X were a side port (meaning separate) from the regular PCI bus. I have no idea how they are handling it with the newer socket 1156 stuff. I sent a email to a HD3 (or HD4) user on the old ASUS P5DG2 WS but he can't remember and is currently snowed in at a pub and can't get to the studio to check....Poor boy.
I know the PCIe cards are only PCIe x1 but that doesn't mean they are using the whole band width. The old ASUS P4C800-E Deluxe held 5 HD cards in 5 regular 32bit slotz and never suffered from bandwidth issues that I'm aware of.
Scott
Core 2 Specs Page
Old 01-08-2010, 11:36 AM
Thats what i have now, (abiet the Pro version)
My Magma chassis with my HD3 is connected to one of the PCIX slots,
Then i have a TC Powercore MK2 in the other PCIX
A Powercore Element in a PCI slot
And a Powercore firewire, a Liquid Mix 32 and an SSL Duende firewire,
All running very well together so i cant complain about the 975X Chipset at all,
But i couldnt get it all to work in my Gigabyte P35 board so i sold it off,
Im just trying to get as much info as possible ready for when i need more CPU/FSB Power in the future,
The main reason i bought the chassis was that i was more and more aware of PCIX getting killed off and i cant afford a PCIe cards upgrade.
I just hope it was a worthwhile move for me :)
Old 01-08-2010, 01:33 PM
RyanC RyanC is offline
Lets do the math. . .
132MB/s (x 1mil)=132,000,000B/s (x8- 8 bits in a byte)=1,056,000,000bit/s
a 24 bit stream at 44.1 uses 1,058,400bit/s (44100x24).
So a fully realized 32/33 PCI bus should Be capable of roughly 1000 tracks of 24/44.1. . . or 1000 TDM voices (997 to be exact) @ 44.1.
Of course it is a 32 bit conduit, so most likely the 24 bit data goes through with one empty byte so each voice uses 1,411,200bits/s (look familiar?). Which cuts us down to 748 TDM voices. Also PT would need to send lots of other stuff to the cards too, like automation data etc. Also a PCI bus is unlikely to be capable of 132MB/s in reality. Realistically something more like 100MB/s, but regardless 32/33 should be more than enough to realize PTHD's highest voice settings.
In older boards, there was loads of other stuff sharing the PCI bus, so this was problematic, but now that almost everything is either directly connected to the NB or SB on the board, or via PCIe (all the integrated stufff), the PCI slots should be more or less alone.
You should not run your HD cards higher than 33mhz, if you did you would be overclocking them and could expect to fry one (probably almost instantly if the bus was running at 133). That said I doubt your mobo would actually let you do that. But regardless you should either have it set to 33 or auto.
Anyone try that gigabyte board with the 4 PCI slots yet?
  #16
Old 01-08-2010, 01:44 PM
Thanks for the math So PCI bus bandwidth shouldn't be an issue assuming theres no other interupts.
Scott
Core 2 Specs Page
  #17
Old 01-08-2010, 02:25 PM
Yeah thats the one. I got the name wrong. Its a bit of a tougue twister. And I was going from memory. Bob Nagy, NickH, and Guitarzan all are running the same board. Last I knew NickH was running HD3 and thinking about HD4. Its a good board.
Scott
Core 2 Specs Page
  #18
Old 01-08-2010, 02:26 PM
Thanks for the Maths !
Is it really that simple?
  #19
Old 01-08-2010, 05:21 PM
kirkgale kirkgale is offline
Tested dumbing down the PCI-x slots to 33 Mghz (since the Auto setting wasn't curing the problem.
No change in behavior (i.e., even opening, closing or dragging a VI window causes "PT not responding" messages and freezing...can't even exit the program)....just using 2 cards in the PCI-x slots on Auto is stable heaven...
Armed with the "new" info that these PCI-x cards are really PCI cards, I am ready to change motherboards to be able to run more than HD2.
Anyone know of an LGA Socket 1366 Board w 3 adjacent PCI slots...?
kirk
  #20
Old 01-08-2010, 06:17 PM
x9blade x9blade is offline
i am running the gap35 s3g with 4 cards at times with 5 cards, it works!!!
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4
32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE
Which graphics card lets me use all PCIx slots? markthompson Pro Tools TDM Systems (Mac) 6 08-26-2009 06:38 PM
Problem with DSP "Not Enough DSP or Time Slots" hef Post - Surround - Video 9 03-25-2007 03:19 PM
Card order in PCI slots s.d. finley Pro Tools TDM Systems (Mac) 3 06-22-2006 02:32 PM
96 i/o card slots PSI General Discussion 2 12-16-2002 05:29 AM
Best slots for 001 PCI card and RAM chips? imp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-06-2001 08:46 AM
