Old 03-28-2012, 04:41 PM
jwd65 jwd65 is offline
Default Recordings won't play back at right pitch-help much appreciated
Hi all,
I've got a humdinger of a problem I could really used advice on. Please read a little further to see if you have any ideas.
Did a band recording about six weeks ago. Used a Beringher ADA 8000 as the lightpipe input for some tracks, set at 48k. Also used it as the sync for the hardware.
Tried to do overdubs a few days later and noticed the recordings wouldn't play back at the right pitch, tried toggling back and forth between ADAT and internal as the hardware sync. Did this for a quite a while to no avail, then viola', it came out of it and played at the right pitch.
Now a few weeks later, it's mixdown time. Same problem and I can't get it to snap out of it. Setting the sync on ADAT, it plays back ridculously fast. Set on Internal, it's almost a full step below pitch.
Any ideas? This is a seriously stressful problem and any help is appreciated.
JD
Old 03-28-2012, 05:51 PM
RTFM RTFM is offline
Default Re: Recordings won't play back at right pitch-help much appreciated
Your session sample rate is different than the actual sample rate of the files. Create a new session at the correct sample rate and use 'Import Session Data' to import files from the original session and make sure to uncheck SRC.
Old 03-30-2012, 12:19 PM
RTFM,
Thanks very much for replying!
I did try this and it didn't work
If anyone's ever run into this issue and tried something different that worked, please let us know.
Any help appreciated,
JD
Recording playing back at different speed and pitch. Ripley1046 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-27-2009 01:50 PM
recordings playing back at twice the speed Tommy Heanue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-16-2009 01:11 PM
Audio/Recordings won't play over speakers...HELP ReyD8 Pro Tools M-Powered (Win) 4 11-17-2008 05:06 PM
Problem hearing back my recordings in pro tools shawn wytch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-20-2007 10:53 AM
Digital feed back on play back after Bounce drew88 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 05-12-2005 01:18 PM
