Old 11-13-2012, 09:58 AM
fm_xtk fm_xtk is offline
Default PT quits every time I change an output assignment
Pro Tools unexpectedly quits every time the following occurs:
When I change the output assignment of a track that has pan automation on it.
Sometimes it gets to the alert warning me that automation will be lost if I change the output assignment, sometimes it crashes before I get the alert.
The crash also happens when I delete the pan automation before changing the output assignments.
Sometimes the the crash even happens when there is no pan automation and I am changing the OP assignments for multiple tracks to the same bus. It never happens when I select a physical output.
Here is what I am doing: I am mixing an album where guitars were recorded through multiple amps at the same time with one track per amp. I want to bus all three tracks into an aux fader. When selecting the three tracks and changing the OP to a bus the crash happens randomly.
Any help appreciated
2x Hackintosh X79
HD7 Accel PCIe, Magma EB7 chassis
PT 10.3.10 Mac OS 10.9.5
SSL Delta Link HD 160 I/O
COCKOS REAPER (latest)
RME MADIFX (192 I/O)
ProControl (32 channel)
Old 11-13-2012, 02:00 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: PT quits every time I change an output assignment
Does it happen in every session? Or just one. If just one try creating a new session and use import session data to import the old session into the new one.
Might need to trash All Avid and pro tools prefs user/library/ prefs
And then the old chestnut that causes many quits are your plugins all compatible and up to date? All plugins are loaded into the cache and can cause issues even if not in the session!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-13-2012, 02:38 PM
It's been happening across all songs. I have had a reply from Waves support on another issue and they told me that I had two different Wave Shells in my system - weird since I just updated from one version to the next.
I am hopeful that this has fixed the problem.
2x Hackintosh X79
Old 05-18-2017, 04:28 AM
jacko's Avatar
jacko jacko is offline
Have you sorted out your problem?
UAD Apollo x16,
UAD Apollo Twin Duo,
UAD Octo Thunderbolt,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
Arturia Beastep for DAW control,
Former Pro Tools HD user (from V7 until V12.6).
Old 05-18-2017, 05:52 AM
I honestly do not remember how it was fixed but I can't remember encountering this problem in a long time (original post was from 2012).
Do you have the same problem?
2x Hackintosh X79
Artist Mix - Eucon 3.0 introduces a new output/bus assignment scheme in Pro tools 11 Emcha_audio Artist Series 1 09-24-2013 01:39 AM
Tempo change causing midi volume to change plugin output tgrfox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-05-2011 01:08 PM
Stereo outputs not showing or working in output assignment path!! crizdee Pro Tools TDM Systems (Mac) 2 12-03-2010 11:23 AM
Output assignment bug pmklein Pro Tools M-Powered (Win) 0 07-01-2009 05:00 PM
Structure output assignment problems Extreme Mixing Virtual Instruments 0 11-19-2007 02:19 PM
