Session Crashes when i try to re-open it.
Running PT 6.4.1 with OS X (10.3.4) TDM Mix plus System with 3 888. I am able to wok just find but when i close the session and then try to re-open it PT will crash during the loading sequence. I have to create a new session then imp0rt tracks data to recover the session. I can keep working on the new session but when i close it the same problem occurs.
MacBook Pro 2.2GHz Intel Core i7, 8GB 1333 MHz DDR3 SDRAM. OS X 10.8.2 MBOX 2pro, PT LE 9.0.6 |
Re: Session Crashes when i try to re-open it.
Try all the recommendations in the trouble shooting thread at the top of this forum!! try first, delete all digi preferences. and all digi database folders on all the hard drives. This usually does the trick with such problems. Good luck, and come back if non of the trouble shooting thread works. Chris
I have done that, i also tried to re-install protool and still the same result.
Are you possibly using the same plug-in on all these sessions? It could be a corrupt plug-in that's causing this, at least that seems the most likely possibility.
Pro Tools 9 crashes every time I open a new session or import session data | Ryan Butler | macOS | 14 | 03-23-2014 07:53 AM |
Started getting buggy, now crashes on open session | [email protected] | Pro Tools HDX & HD Native Systems (Mac) | 5 | 08-31-2011 12:07 AM |
PT crashes when I open a session | Chief Pronto | Pro Tools M-Powered (Win) | 0 | 08-29-2008 01:54 PM |
Can't open LE session....PT HD crashes | Media Man | Pro Tools TDM Systems (Mac) | 8 | 04-11-2008 12:24 PM |
PT crashes when trying to open session | mr.armadillo | Pro Tools TDM Systems (Mac) | 8 | 03-18-2008 12:52 AM |
