Old 07-08-2012, 06:10 PM
510man 510man is offline
Default Bounced PT WAV Not Recognized by Other Apps
I've created a bunch of 44/16 drum samples in PT. Multiple applications do not recognize the files as valid WAV files. I Googled the problem. It appears that PT creates a broadcast WAV and many applications are looking for a simple WAV.
A couple questions:
1) How do I convert the samples I have from broadcast to simple WAV?
2) How do I set PT so the bounce is to a simple WAV as a default?
Thanks for any help.
Old 07-09-2012, 11:28 AM
Top Jimmy's Avatar
Default Re: Bounced PT WAV Not Recognized by Other Apps
  1. You can use iTunes to batch convert to simple wavs.
  2. You can't.
In iTunes, set the Import Settings to Wav and Auto, and uncheck the "Copy files when adding" option under the Advanced tab. Drag all your samples into iTunes, select them all and choose "Create Wav version" under the Advanced menu. Once done copying, select all of the sample (original and copies) and delete, sending the new files to the trash. Fish the samples out of the trash bin and you will now have simple wav files.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.6.
Pro Tools Ultimate 2021.3, HD Native, Focusrite Red 8Pre (Mac)
Pro Tools 2020.12, Mbox3 (Win)
Old 07-10-2012, 12:51 PM
Thanks, that worked great!!!
CoreAudio Problem, Mbox 2 Mini Recognized but No Sound Through Any Apps/Hanging DAW's WhiiteNoiise 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-16-2012 01:22 PM
CoreAudio problem. Mbox Mini 2 Recognized, but no sound through any apps. WhiiteNoiise General Discussion 0 03-15-2012 02:13 PM
Bounced around ( ? ) basslik macOS 4 06-27-2011 04:10 PM
Anyone using C8 with apps other than PT? silverlode ProControl, Control|24, Command|8 4 09-05-2004 11:05 AM
PT6 & other apps C Craig 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-10-2003 12:46 AM
