Old 03-06-2009, 02:56 PM
510man 510man is offline
Default Edit MIDI Pitch Control
Where is the MIDI pitch control editor in LE 7.3? I imported a MIDI track where the bass has WAY to much expression. I need to dial it back or turn it off. I don't see a parameter to do it in the MIDI edit window. Is there no way to edit it post recording? What am I missing?
Thanks for any help.
Old 03-06-2009, 04:34 PM
SeedGuy SeedGuy is offline
Default Re: Edit MIDI Pitch Control
Have you checked every view on the MIDI track? There could be either pitchbend, modulation, or any CC that has been mapped to a modulation parameter within your VI/Sound Module.
What VI/Sound Module are you using for your bass sounds?
Old 03-06-2009, 06:29 PM
miek07 miek07 is offline
Select your mndi region and press "CTL + =" (or mac equilivilant) and filter out MIDI notes. Look for CC, SYSEX , or other Controller messages contained in that region. If its a CC transmission, you need to manually enable CC## edit by selecting your WAVEFORM/REGION/MIDI selector and move to the bottom selection to CC, you will see a list of CC1 MOD WHEEL CC7 Volume CC10 Pan etc... the bommem gives you the optin to add more CC paramaters.
Open more Paramaners and select form the list of 1-30 31-60 61-90 91-127 (something like that) and away you go...
michae
myspace.com/miekwavesoundlab
Edit pitch bend midi data bwandon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-24-2018 08:20 PM
Use MIDI to control buttons in the edit window? toolfanem Pro Tools 10 0 12-17-2012 01:31 PM
8 pitch control jimskiwax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-04-2008 03:37 PM
How do I Edit PItch and Volume levels 5.1.1 mcollins504 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-05-2007 11:56 PM
Pitch control w/ LE? jpoprock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-04-2003 03:53 PM
