pro tools 6.1 and intel i7
Can anyone tell me or is anyone still using pro tools 6.1 with the 001 in a new i5 or i7 computer with windows xp???...also are all rtas plugin backward compatible?...example using the plugins with pt 8....lastly is rewire a program within pt 8 and will work with older out dated programs like gigastudio 160?
Re: pro tools 6.1 and intel i7
I would think the main issue would be the O/S - if you stick with XP then you're probably ok whereas with Windows 7 some plugins may not be compatible.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
No. Quote:
You are most likely going to run into a host of problems trying to use older hardware/software on a newer computer. I'm just curious; why not upgrade? There are a host of options available, and the newer versions of all software are going to be able to take advantage of the advances in the newer computer, where the older software will not. There are much better options these days than Gigastudio (IMHO), and many of them can utilize the Gigastudio libraries.
ty for starters the 001 interface is way better then the mbox series..as per rewire and gigastudio..well to cut cost why not?...I do have pt 6.1 running on a older puter with the 001 interface....i got a mac with the pt 8..mbox2 pro...there is a difference...the older pt u dont need to get a rtas wrapper for some of the vst's i have...giga studio is a windows program...yea i know i could update to a 003 for a mac for maybe the same cost or better...i like the fact that u dont need wrappers on the older pt system and i like the fact that what i have on the mac sounds better on the older pt...maybe it is the audio interface on the mac..mbox2..i dont know...yes the older pt is running on windows xp pro.
How much is your time worth? You may spend more time "geeking out" trying to get it to work than actually working with it. My personal opinion, I would rather spend a couple of bucks and get something that will just install and play than spend days/weeks/months trying to get some older piece of software to work, and living with the headaches that it is inevitably going to produce. (again, maybe that is just me, I dunno.) Quote:
I'm still extremely confused by this. Again, NO version of Pro Tools uses VST formatted plugins natively. None. They all need the wrapper to be able to do that.
ty spkguitar..i appreciate what u said....but pt 6.1 will run the real guitar series...vsti or vst..without a wrapper.dimension pro the same..as per sample tank 2.5 thats already compatible...as per gigastudio 160 it does work on a older computer with windows xp pro and can be rewired into pt 6.1......if i failed to mention my concern it would be with a newer computer and this configuration....i am in the belief that all would work since its only a upgrade of the componets in a newer computer...which i am looking at a quad type...same operating system no different then whats on its now....if i am wrong pls correct me....worse case if 6.1 and the 001 dont work on it...i can always install the windows version of my mbox2 pro and get a firewire port installed on the puter...yes i do a wrapper program for the above mention programs..but then i would be uncertain if gigastudio would work with it...as per spending a few bucks on a newer program...it really wouldnt be a few bucks now would it....more like a few hundred..and i have tried the giga files on the mac with their compatible programs...sound is subjective but..its not like what i heard on the old windows puter thru the 001 or sound card...any other suggestions i would appreciate hearing...and i hope i didnt come off being rude..just telling the facts from what i have here.
Fact: no version of Pro Tools can use VST or VSTi without the wrapper. None. If you are using a plugin directly in Pro Tools without wrapping first, it must have RTAS compatibility. That is a fact. Quote:
With the real versions of Real Guitar, you would need the wrapper. The only versions of Real Guitar that I have seen that have RTAS compatibility without the wrapper are cracked/torrent versions. You certainly aren't using cracked/torrent versions, are you? Dimension Pro is RTAS. It wouldn't need to be wrapped, even on newer systems. Quote:
Ty...but i'm a bit confused on the 6.1 and real guitar...its working and i got no wrapper on it...its the first version of it...maybe the later versions u need a wrapper..anyhow ty very much for the info...i'm still decidin which course of action to take
Where did you get it?
musiclabs...the manufacturer
Intel X-25M 80 Gig SSD and Pro Tools LE! | gearhead2010 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-20-2010 12:40 PM |
Pro Tools HD with Intel i7 cpu | KKalampo | Pro Tools TDM Systems (Win) | 27 | 11-27-2009 08:57 PM |
GRM Tools go Intel | mindnoise | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-27-2006 05:51 PM |
GRM Tools for Intel Mac | whtrabit | Pro Tools TDM Systems (Mac) | 0 | 12-27-2006 05:36 PM |
intel and pro tools? | LadyElectrikStudios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-20-2002 04:21 PM |
