Old 05-15-2018, 11:10 PM
Qwoll Qwoll is offline
Default New to protools, and I'm super confused about instruments???
So...
I just got the full version of protools. Now the last composing software I used was mixcraft, which, if you dont know it, is similar to garage band.
So when I opened protools, I was dumbfounded by the fact that I only had like 7 instruments, and that buying new ones, individually costs from like 20 to 300 dollars.
I'm super confused by this. How is this practical at all? I'm used to having all the instruments right at my fingertips from a built in library of sounds.
And what do I do to get instruments?
Old 05-16-2018, 09:29 AM
Top Jimmy's Avatar
Originally Posted by Qwoll View Post
So...
Xpand is a sampler with a decent fundamental library. You'll find many different instruments and sounds there. All the other included instruments are single purpose (piano, organ, synth, beats).
You can add 3rd party instruments as long as they are AAX format, not VST.
James Cadwallader
Old 05-21-2018, 03:07 AM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Default Re: New to protools, and I'm super confused about instruments???
So...
If you have other VST or AU instruments that you used in previous DAWs, you can host them in PT via Blue Cat Patchwork or Vienna Ensemble Pro. These two hosts work well in Pro Tools.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 05-21-2018, 06:54 AM
The Weed's Avatar
The Weed The Weed is offline
Pro Tools is an audio editing/mixing program with some sequencing abilities, not a sequencing program. Yes, there are some instruments built in, but not many. However, as said, if you have some instruments in VST format, they can be used in PT with a "bridge". But there are a huge number of third party instruments you can purchase to use with PT, many that are superior to any supplied with a program. I'm sure the more instrument knowledgeable on the forum would be happy to list their favorites for you if you tell us what you're looking for and their use. There are many, many Pro Tools users who sequence in a different program and then import the resulting audio files into PT to mix down. As always, YMMV.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 05-21-2018, 09:40 PM
Brian Hudson Brian Hudson is offline
Hybrid 3 is a lot of fun and also BioTek but it crashes ProTools with automation sometimes
Brian Hudson
Old 05-22-2018, 04:31 AM
Started out doing my MIDI work in PT then brought Digital Performer into the equation because I listened to those who said the MIDI work in PT wasn't quite up to snuff. After about a year of that dual nonsense I'm now back to working pretty much exclusively in PT for everything. PT can do it all if one has the patience to work with it.
As far as my favorite vi's in no particular they are:
NI Kontakt 5 (sampler)
IKMM Sampletank 3 (sampler)
Air Velvet for Rhodes
Arturia Synclavier V
Arturia Moog Modular and MiniMoog
Jack
QAPLA!
Old 05-22-2018, 03:32 PM
bashville bashville is offline
So...
Other DAW's particularly Logic, Reason, and I think StudioOne probably have better instant gratification instruments supplied with them. ProTools has always been the pro editing and mixing app of choice but was a little late to the game with midi features and in-app VIs. I used to link Logic and PT together, but since PT8 have preferred to stay in ProTools after they seriously upped their midi game. Preferred 3rd party VIs include anything by Spectrasonics, drums from BFD and general sample library stuff from Native Instruments. Both Kontakt and Digi's own Structure will playback all the ancient Logic and Samplecell format libraries. Avid's Xpand works fine for most hit and run idea work.
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur
Old 05-25-2018, 05:16 PM
SigFriedChicken's Avatar
SigFriedChicken SigFriedChicken is offline
I think Avid offers a subscription to their plug-in bundle.
Most PT users already have third-party plugins that they use. No one buys PT for the plugins. Not that they are bad. It's just that PT is primarily used for recording, mixing, and post-production. If you want a DAW that comes with a ton of nice plugins, look at Logic.
Old 05-30-2018, 09:08 PM
These are the included plugins, according to Avid's website:
http://www.avid.com/pro-tools/included-plug-ins
It was initially a bit confusing to me which ones were included and which ones require a separate subscription.
Old 06-20-2018, 04:23 PM
jpmorgan jpmorgan is offline
ProTools contains Expand2, which has many virtual instruments, sounds and effects. Everyone has different preferences for different needs, but you might additionally consider purchasing Native Instruments' Kontakt 5.
Super cool Kontakt Samples Dronar from Gothic Instruments free Southsidemusic Virtual Instruments 7 07-15-2017 10:54 AM
New to Protools and Confused SickTheory Windows 7 07-01-2011 08:23 PM
super long protools startup feakerboo Pro Tools TDM Systems (Mac) 4 12-02-2009 01:04 PM
Protools questions from a confused beginner... shoeshine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-29-2004 05:18 AM
Small improvement would make protools a super live tool!!! augustengkilde Pro Tools TDM Systems (Mac) 2 09-04-2001 12:54 AM
