Old 12-14-2019, 11:07 AM
wwittman wwittman is offline
Default -9173 errors...
so i started getting some 9173 errors
and I tried going into Terminal and doing what it suggests here:
http://avid.force.com/pkb/articles/T...-Errors-on-Mac
but it doesn't seem to have helped
so my question is, how do I restore the previous settings?
that seems missing from that article
thanks
Old 12-14-2019, 01:05 PM
Mixchump Mixchump is offline
Default Re: -9173 errors...
This error is the defining one of this particular era of ProTools. I get this constantly, and I've done all the suggested tweaks. I'll stay tuned, and wish I could be of more help.
I print mixes to an external DSD recorder, and it sometimes takes me 2 or 3 tries to get through the entire song when playing through.
Old 12-14-2019, 01:08 PM
I should also add that I have done a complete ground-up install on a freshly formatted SSD of High Sierra (several times), and all of the applications and Plug-ins... Exact. Same. Problems.
Old 12-14-2019, 01:26 PM
yes
BUT... anyone have a hint how to restore those things changed in Terminal that didn't work there?
William Wittman
Producer/Engineer
(Cyndi Lauper, Joan Osborne, The Fixx, The Outfield, Hooters...Kinky Boots!)
Old 12-14-2019, 02:57 PM
Weird thing about these errors is I worked all day yesterday on this track and it ran perfectly every single time.
Come back today and it won’t play more than a few bars without complaining and falling over.
SOME process must go on somewhere that causes it but damned if I can tell what.
William Wittman
Producer/Engineer
Old 12-14-2019, 03:00 PM
clivvy clivvy is offline
Terminal is not going to solve this problem its been ongoing for a year or more at this point could be a Avid problem or Mac osx or 3rd party plugin!
Old 12-14-2019, 05:58 PM
innesireinar innesireinar is offline
Did you add new plugins?
From my experience there are some plugins that could cause this annoying issue. These are kontakt 5, Spire (Reveal Sound) and Ozone. They affect the play even if no instatiated. You have to remove them from the plugin folder before starting pt
Hope this helps
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11
Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7
Old 12-14-2019, 09:18 PM
Teej Teej is offline
Have you tried turning Turbo Boost off? I had the same problem with CPU headroom (granted, years ago) where sessions that worked previously would stop working the day aftwer. Turning off Turbo Boost made my system in general much more reliable by using only the guaranteed always-on speeds of the CPU. I still run with Turbo Boost off and these days computers are so fast I don't miss any of the Turbo at all. Might not be your issue but if you haven't tried it it's worth a shot...
Old 12-14-2019, 09:30 PM
ZEUSS ZEUSS is offline
I actually did the terminal thing on 2 machines that always gave me the error randomly with clean up to date installs. My new 2019 MacBook Pro and my trashcan. And I haven’t seen it happen since. Knock on wood....
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1
Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX.
Old 12-14-2019, 10:49 PM
Hope this helps
no, nothing new.
thanks though
William Wittman
Producer/Engineer
About the 9173 errors and Mac users jchan Pro Tools 2018 2 05-07-2019 05:34 PM
-9173 Errors due to Native plugins DJ Hellfire Pro Tools 12 33 05-05-2018 07:09 AM
More AAE -9173 Errors, At Wits End! Cota332 Pro Tools 12 3 04-28-2017 07:38 AM
CPU Power issues AAE -9173 errors Cryos Pro Tools 11 3 11-01-2015 03:39 AM
CPU 50-50% PT, 22% PC: Why? 9173 Errors dougdude9 Pro Tools 11 14 03-23-2015 03:58 PM
