DADman Routing Results -3db Loss
I'm hoping there's a simple answer as we're new to DADman and Dante.
Until incorporating DADman in our setup with a new MTRX ST, we have successfully been operating a modified Native Atmos setup. We routed live rerenders from DAPS to Source Nexus so we can pick them up in PT for measurement and outputs. Everything worked great! Now, using DADman and the MTRX ST, we are routing live rerenders in DAPS from DigiLink to Dante in DADman, then Dante to DVS in the Dante Controller, and then DVS to Source Nexus in Pro Tools. However, the signal is coming back -3db lower. When we switch between the 2 setups, the results are consistent, which confirms something is up with DADman and/or Dante causing a -3db result. Did we miss something during setup that would explains this? Thanks. |
Re: DADman Routing Results -3db Loss
We can eliminate Dante altogether by sending live rerenders in DAPS from DigiLink to DigiLink in DADman, and pick them up with Source Nexus in PT ... and we still get the same result.
Did we miss something in the DADman setup as it seems the issue is with DADman? Thanks. |
Have you tried skipping DAPs and just checking a sine 1k tone from digilink to digilink looped through the MTRX Studio?
DADman doesn't change levels unless running through the ProMon (monitoring) section. Double-checked it here (on a full MTRX though there should be no difference) and it is still as accurate as ever. When you say you are routing DAPS to digilink, I assume that is direct? Which would mean you are using the CoreAudio driver model for digilink. CoreAudio has gain level/trim possibilities (in Audio/MIDI Setup)
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Ugh .... Yes, of course! AMS output set to -3.
Does a new unit default to -3 in AMS? We never touch it! Thanks for the quick fix. |
Aurora N32 routing via HDX in DADman? | cabbagerock | Third Party Interfaces | 0 | 12-26-2020 04:59 PM |
DADMan 2.1 routing out of Mac | Goombot | Pro Tools 2020 | 3 | 10-21-2020 08:08 AM |
DADman disconnects | pkingduk | Pro Tools HDX & HD Native Systems (Mac) | 12 | 07-26-2020 04:22 AM |
loss of a redundant connection loss protools device S3L-X | Matysiak.m.d | VENUE Live Sound Systems | 8 | 01-25-2017 06:26 AM |
PT Crackling/Quality Loss/Eventual loss of sound | WhyAvid | Pro Tools 12 | 10 | 01-10-2016 08:37 PM |
