Old 10-15-2019, 01:39 PM
johnnyv johnnyv is offline
Default Re: One of the strangest things I've ever seen. Anyone have ideas?
Ok. Once again, thanks for pointing me towards properly updating the firmware in our Sync HD units. They have both now been properly updated, with the update software in each case confirming that the update was successful.
Sadly, our problem still exists in both rooms.
I'd like to interject here that we discovered this problem when we were recording a multi-mic setup on piano. Piano can be a very sustained instrument which would nicely illustrate clocking issues. I would think more so than even sensitive dialogue where words are changing and a mis-matched clock would have less "sustained" passages to try to navigate and maintain. And, we have found that having half a dozen mics on the piano exacerbates the issue even further. Anyway, just wanted to throw that into this discussion
What we have so far found that works the best is if we clock the Sync HD to a black burst generator which is plugged (via BNC) into the Sync HD "Video Ref" and then set our clock source in the ProTools Session Window to Video Reference.
But I sure wish I could figure out why the Sych HD is giving us the ticks ONLY when it's clocked internally.
So odd to me.
Old 10-15-2019, 01:55 PM
JFreak's Avatar
JFreak JFreak is offline
Sync HD is not going to give any ticks, but one interface or A/D not clocked properly. Troubleshooting may be tricky at times, so what you should do is simplify your setup.
As in disconnect any external reference your Sync HD is receiving, re-seat connections to all the interfaces' Loop Sync configuration and THEN one by one connect the A/D -- with current cables -- and see if you can spot one problematic device. If you only connect one A/D you will spot the problematic device. And then, first double-check that device is syncing to your clock properly, and if it doesn't help change the WC cable.
Janne
Old 10-15-2019, 04:50 PM
JFreak,
Yes, super helpful and a good reminder. Most likely we will follow those exact steps as we continue the testing. We have sessions running in between the testing, so it takes us some time to try new things.
In light of your comments, there are two odd things:
The first thing, especially in light of the good audio testing principles that you've laid out is that the exact same thing is happening in both of our rooms which generally speaking remain intact (equipment not moving around on any sort of a frequent basis). And these ticks are SUPER low level, which makes me even wonder if our situation might actually be common to many studios using a Hearback Pro, but they remain undetected for differing reasons (source material, number of mics involved, etc).
Second, these little ticks ARE ONLY IN THE HEADPHONES, NOT in the audio we are recording. So one would have to suspect something involving the clocking of the Hearback system (not putting fault there necessarily).
And I want to remind you of the most puzzling aspect:
By clocking either of our systems to a Horita black burst generator, there are no clicks, which does throw suspicion (wouldn't rule anything out but...) on answers such as a bad WC cable...would the cable be bad when Sync is internal but then be good when Sync is external? Would be hard to imagine that, for instance, we had at least one bad WC cable in each room, but both of those bad cables work perfectly fine when a black burst gen is referenced for clocking.
We've got sessions for the next few days, and we'll be using our Horita's, but hopefully we can get back to this next week.
Super strange that the Hearbacks work perfectly if the Sync is clocked externally.
Old 10-15-2019, 08:43 PM
Top Jimmy's Avatar
I quickly scanned the posts and see no mention that the sync HD is loop sync master. Do you have loop sync setup between the sync HD and the interfaces?
James Cadwallader
Old 10-15-2019, 11:24 PM
Hey Jimmy,
Thanks for jumping in. Yes, the Sync HD is Loop Sync Master, with the Loop Sync light properly lit on its "underlings". And that's true in both rooms.
Strangest Thing HDN TB / Symphony syMPh Pro Tools 12 1 12-14-2016 04:53 AM
Strangest Behaviour! Arrun macOS 5 04-24-2013 08:06 AM
Hmmm, I cant move things about in my edit window. Any ideas? AtomicLongie Pro Tools 9 3 04-25-2011 12:27 PM
Strangest error message sass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-06-2007 04:47 AM
Pro Tools doing weird things.... any ideas? Dan T 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-23-2004 03:48 PM
