Old 11-05-2019, 11:26 AM
BaeckBeatz BaeckBeatz is offline
Default Plugin not showing in pt11
Hey
I'm using Pro Tools 11 on windows 10.
If a plugin isn't showing up in PT does that mean that it's probably not an aax? It only says .dll in the folders. And I've tried in all possible plugin folders I can find.
It's a free plugin called Neopiano.. Or Piano1.
Same with Iowa flute.
A bunch of other plugins I have that works are just listed as .dll so..?
Thanks
Old 11-05-2019, 11:29 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Plugin not showing in pt11
Hi, welcome to the community.
PT11 and later only support 64-bit AAX
Janne
Old 11-05-2019, 11:37 AM
Thanks..
And I just saw that the piano plugin was vst 32 and 64 only. No aax then I guess. You can delete thread. I guess that is why it won't show.
HTML code is On
battery not showing up in pt11 lucidlife AAX Plug-ins 3 08-01-2015 05:39 AM
Trilian not showing in PT11 cleopatra1 Pro Tools 11 0 02-26-2015 10:30 AM
Is Structure 2 Showing Up In Your PT11? LightWing AAX Plug-ins 3 10-26-2013 09:34 PM
PT11 plugins not showing up lordtom Pro Tools 11 11 09-30-2013 03:25 AM
VEPRO5 not showing up in PT11 massimosammi AAX Plug-ins 3 07-15-2013 05:02 AM
