Old 02-09-2020, 02:59 AM
Kinh Kinh is offline
Default Protools sucking the memory out of my drive
Recently protools started up it's usual crashing antics for no good reason and that's what I expect but the problem this time round is it seems to be eating up the memory of my system drive every time I run it then close or it crashes and closes.
Windows created a temporary paging file on my PTs drive E the first time it crashed yet my memory is being zapped out of my C system drive.
Intel 6 Core i7-4930K CPU @ 3.40GHz
32GB DIMM DDR3 G.Skill
Samsung SSD 840 EVO
WD Black SATA 7200
ASUS SABERTOOTH X79
Windows 7 Ultimate 64
Mbox3 Pro Firewire 400
ProTools 10.3.8
ProTools 11.3.1
https://soundcloud.com/matthewcrowe
Old 02-13-2020, 03:10 PM
Default Re: Protools sucking the memory out of my drive
Since nobody has tried to help, I'm guessing others are as confused as I am about this as your description doesn't make much sense to me
Why? Consider:
1-"memory" is RAM and RAM is not your hard drive.
2-"crashing antics for no good reason", I have no idea what you mean. Many of us run Pro Tools daily with little to zero crashing.
3-you give zero detail on your PC so nobody can guess why you have crashes
4-if you have a properly spec'd PC, then you likely have 32GB of RAM, in which case you should turn Paging File off.
5-what troubleshooting have you done? Trashing prefs is worth a try for any "odd behavior"(and what you are describing sure seems odd to me).
6-look near the top of this(and every) DUC page for the link named Help Us Help You and have a good read. Then come back with relevant information so someone has a fighting chance at helping
12.5 sucking big time today Carl Lie Pro Tools 12 7 05-29-2016 08:46 PM
Why is 12 sucking SO BAD?!? Siegfried Meier Pro Tools 12 66 09-17-2015 04:43 PM
the sucking sound bjonesAAB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 12-21-2007 09:10 PM
Sucking RAM + distorted tracks dougchase 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-19-2004 04:08 PM
sucking in vocal effect??? Dr. J Tips & Tricks 3 12-29-2001 07:04 AM
