Old 08-21-2013, 07:06 AM
Firechild Firechild is offline
Default MIDI bug - Transpose
When transposing with Event Operations Poly Aftertouch will not be "transposed". I guess MIDI Real Time Properties is not doing Poly AT right either.
iMac Pro - HDX2 - Mojave - AVID HD I/O x7
Old 08-21-2013, 10:13 AM
Default Re: MIDI bug - Transpose
I'm confused(but I am not a midi "power user"). Wouldn't aftertouch be a non-pitch related parameter(so there would be no need to "transpose" it anymore than transposing sustain or pitch wheel)?
Old 08-23-2013, 04:56 AM
You are referring to the more common aftertouch, channel aftertouch or monophonic aftertouch, I am referring to Polyphonic aftertouch where you can apply different aftertouch to different keys. I´ve got a Roland A-80 master keyboard that send polyphonic AT and I ´ve got a couple of hardware synths that can receive Poly AT.
Old 08-23-2013, 06:05 AM
Understood but I don't see how key pressure (which is all aftertouch in any form is) would be affected by transpose. PT would not see it as a MIDI note number which is really what transpose works on. PT won't know you have polyphonic aftertouch programmed in your synths for pitch bend which is what I assume you're using it for because after all that's for the synth to decode and not PT.
Jack
QAPLA!
Old 03-23-2020, 11:28 AM
Any news on this. is it working in the latest update?
Poly at means aftertouch per key, meaning if you transpose the MIDI sequence the poly at info should transpose as well otherwise there will be aftertouch on keys you are not playing :)
It does work in Logic Pro X if using the track parameters.
Old 03-24-2020, 04:42 AM
I still stand by what I wrote almost seven years ago. PT doesn't see aftertouch as a MIDI note change which is what MIDI transpose works on.
Jack
QAPLA!
Old 03-27-2020, 07:42 AM
Then Pro Tools are wrong
However even Logic Pro X is a bit confused...when using track parameters the poly at will transpose as well (which should be the only way and 100% logical), but if using region parameters poly at will not follow transpose.
transpose Jel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-19-2009 08:44 PM
MIDI Realtime Properties(Transpose) forgotten on reload... perh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-25-2008 10:03 PM
Transpose incoming midi justmull1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-18-2006 09:57 PM
Midi transpose bug?? Stig Eliassen Pro Tools TDM Systems (Mac) 4 06-07-2005 09:31 AM
Midi transpose pre record delta MIDI 0 11-04-2003 08:23 AM
