Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 11-30-2020, 12:09 PM
bzone bzone is offline
Default I/O with HDX Driver in Logic Pro
Just doing a new set up with a New Mac Pro 7.1 Catalina 10.15.5. Pro Tools Ultimate 20.11.0 Avid Audio Server driver 20.11.0. In Logic we are only seeing 32 I/O ? Isn’t it 64 I/O per HDX card. Audio midi Set up on the 7.1 is only showing 32 I/O. Logic 10.6 only showing 32 I/O as well. Logic is 10.6 in the old system all with Pro Tools Ultimate 20.5.0 on a 6.1 had all the outputs? Is it the new Audio Server driver. All this with a B80 Mothership. On the Avid side have all the I/O that is needed per HDX cards. What are we missing? Any info would be appreciated.
Old 11-30-2020, 12:32 PM
XJENSEN XJENSEN is offline
Default Re: I/O with HDX Driver in Logic Pro
Yes, CoreAudio driver is limited to 32 IO outside Pro Tools.
Old 11-30-2020, 05:33 PM
Ok so I’m confused. I spoke with Avid on the phone and they told me the 20.11 driver would give me 64 I/O in Logic with the HDX card. It worked in the old system with the 20.5 driver.. Catalina 10.15. I had a Sonnet fire wire 2 chassis. Now with the new 7.1 Mac Pro it won’t give me the upgraded I/O in Logic? Something is off here?
Old 12-01-2020, 02:01 AM
LDS LDS is offline
HDX definitely supports the full 64 channels of I/O when running via core audio. Have you checked your audio midi settings in OSX to see what's what? Perhaps it isn't detecting a digilink interface or something similar?
File Type: png Screen Shot 2020-12-01 at 8.55.11 pm.png (94.7 KB, 0 views)
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 12-01-2020, 08:58 AM
Yes in deed, a bad mini digi link cable. Thanks much. Full 64 I/O now!
Macbook Pro+Logic+002 - do I need a driver? mahler007 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-19-2012 04:30 PM
Help! No DAE driver in logic sgsouder Pro Tools TDM Systems (Mac) 1 08-25-2009 10:02 PM
OS 10.4.3 + Logic Pro 7.1.1 + DigiCoreAudio driver audiowiz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-28-2005 02:41 PM
Mix Plus TDM Audio Driver with Logic cander Pro Tools TDM Systems (Mac) 3 04-15-2003 03:50 AM
001 and logic(which audio driver?) DigiTechSupt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 06-22-2000 07:14 PM
