Old 01-29-2020, 04:25 AM
gafyn gafyn is offline
Default D-Command Auto Banking??
We've recently updated to ProTools 2018.12, and since then the D-command is banking faders when I select a track / plugin, This is super frustrating, especially when recording MIDI tracks, when I select a MIDI track it automatically record arms which is very dangerous.
I prefer to have my faders static when mixing and banking them myself, now everything moves relative to what track I'm working on / editing making my work flow very confusing.
Anyone else have this problem? How do I stop this? I can't find any options in the preferences folder.
Thanks.
There is no Spoon
Old 01-29-2020, 05:11 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: D-Command Auto Banking??
Hey Gafyn
There is a preference that might be causing this if o remember correctly
It’s called auto bank when selected, and your MIDI channel issue is another preference call auto arm (or record) on select
I am not sure that the verbiage I gave you is correct but that is most likely your problem especially since you just updated
Daniel
Old 01-29-2020, 06:34 AM
Sounds like those would do the trick but I can't seem to find these options anywhere in the preferences folder.
There is no Spoon
Old 01-30-2020, 01:48 AM
Update on this issue:
I came in to work this morning and decided not to turn on the Oxygen 88 MIDI Keyboard and there we go - the D-Command doesn't bank to selected tracks.
Why does the Oxygen 88 cause this problem?
There is no Spoon
Old 01-30-2020, 07:32 AM
Sorted - In the peripherals Menu under the MIDI controllers change the Oxygen 88 to none.
Now the banking behaves and the keyboard still works to record MIDI instruments.
There is no Spoon
Pro Tools 10HD Fader banking with Digital Mixer (banking meters too?) HELP! Aehs macOS 1 07-22-2016 11:37 AM
V2.0 - bug - Auto Banking / Hidden tracks Kaneepa Avid S4/S6 2 07-20-2015 02:58 PM
Auto-Banking Question TimNielsen Artist Series 17 08-23-2012 06:08 PM
Auto banking mix window? idris Pro Tools TDM Systems (Mac) 3 08-13-2011 01:39 AM
command 8 banking shortcut? jeremypark ProControl, Control|24, Command|8 4 11-25-2007 07:20 AM
