Old 09-10-2012, 09:14 AM
vikingthor vikingthor is offline
Default Venue Software bugs
Hello,
We use our SC48 on daily basis for all kinds of performance, and are very pleased with it. But since we update our Sc48 to venue 3.0 we came across some weird bugs. We mainly use 24 aux option. And use the last 8 auxes as stereo groups, 48 Input channels, 8 Graphic eq’s. Main busses are L-R plus Mono
MTX 1-2 Surround
MTX 3-4 camera
MTX 5-6 Left-Right
MTX 7 Cluster
MTX 8 Sub
- When I tried to assign aux 12 to Matrix 1-2 I get a loud ‘pop’ on all my other matrixes, feeding the P.A. This sounds like a gun shot during a play!
http://dl.dropbox.com/u/99954944/Ven...8-15-52-36.mp4
http://dl.dropbox.com/u/99954944/Ven...8-15-54-02.mp4
- Selecting group as master out and then adjusting the monitor out encoder variable group 7 follows the level of the monitor out encoder.
http://dl.dropbox.com/u/99954944/Ven...up%20Fader.mp4
- after loading show, pressing for the first time for variable group mode the console often react sluggish (slow metering, slow view paging) for about 15 seconds
http://dl.dropbox.com/u/99954944/Ven...8-15-36-02.mp4
http://dl.dropbox.com/u/99954944/Ven...oup%20mode.mp4
Are there other people out here who experienced the same?
Old 09-10-2012, 11:03 AM
digidesigner digidesigner is offline
Default Re: Venue Software bugs
May I add these:
- Some signal bleeds into talkback mic channel, mic is disconnected.
http://dl.dropbox.com/u/11182503/Tal...-%20iPhone.m4v
And when you try to solo it the level of bleeding signal will drop quite a bit
http://dl.dropbox.com/u/11182503/TalkBack_issue.m4v
- Function key flashes for no reason, all events disabled.
http://dl.dropbox.com/u/11182503/Fun...-%20iPhone.m4v
Old 09-24-2012, 01:29 PM
Mystere1 Mystere1 is offline
Default
I've had the flashing function key on both my profiles pretty much since I've had them.
How about random outputs not passing audio until after a console reboot?
Old 09-24-2012, 01:46 PM
hmm... never have had that, even though I'm using typically 14-16 outputs as I'm doing inears from FOH
Old 10-16-2012, 02:31 PM
Any news for a new update or a work around? did you reconized any of these bugs? Avid? Sheldon?
Some updates of what i am experiencing:
sometimes when using sc48, fx return 4, stereo led flashes, while there isn't any audio coming in, even when i remove the xlr of the input which are assigned to the fx return, it still randomly flashes.
had some stereo channels selected, when pushing the stereo-pan knob, for using 24 variable groups, the console switched back and forth between back-up mode for several times.
while these two things aren't realy shocking, i do find the sound of gun shot trough the PA, by making an adjustment of the matrix input source very shocking!
Old 10-16-2012, 07:20 PM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Thanks for your patience. We've been looking into a few of these. Here's what we know so far...
vikingthor:
This is a known issue, to be fixed in a future release, if possible.
Yep, that's a bug. Sorry. On the list for a fix in a future release.
We can't seem to reproduce this. Does it happen every time for you?
The flashing stereo LED indicates a notable difference in level between the left and right channels making up the stereo pair. This can happen, for example, when only one of the sides (left or right) is patched, while the other is not. Also, there are some reverb plug-ins that can have a different output level between L & R, when no input signal is applied.
Not a known issue, and we can't yet reproduce. Let us know if you can reproduce it at will.
Thanks for bringing these up!
Sheldon
Old 10-16-2012, 07:28 PM
Hi digidesigner,
Comments below...
We're looking into this. Note that the TB mic input is a fixed gain input, with a fairly high input impedance. It's not the same type of mic input as on the stage rack. When the talkback input is unterminated, it's possible to see some noise pickup, due to the high input impedance. This noise is not present when a mic is connected, terminating the circuit. Not sure why the solo level might affect this, though...
This can happen when an event is triggered that starts the button flashing, but then the event is deleted or otherwise not cleared. To fix this, create and trigger a temporary event that forces the function LED to stop flashing. Once stopped, it should not start again unless another event tells it to do so. (So check all events to make sure there isn't an event somewhere inadvertently triggering the flash to begin).
Sheldon
Old 10-17-2012, 12:45 AM
Originally Posted by Sheldon Radford View Post
Hi digidesigner,
Comments below...
Sheldon
The TB mic bleed sounds like a distorted master is bleeding into TB and as you see the level is pretty high even at the default input gain of FX return. As I'm doing monitors from FOH this can smear the IEM mixes. As of now, I have created a rehearsal space for the bands that is built around my Profile with 8 PQ controllers, so I will be having a bit more time to troubleshoot this in a controlled environment. I'll let you know if I'm able to find a pattern how and when this happens.
Old 10-17-2012, 12:01 PM
I did some testing today, it seems that when i load my showfile which has different system settings (at least a different auxes structure) than the showfile which was running before, Than the console always reacts sluggish (mouse, faders, view paging) And sometimes when loading my showfile, it randomly jumps into back-up mode for a few seconds and then it comes back online.
I did make a new showfile with exact the same system settings, plugins, events snapshots. And it dissapeared, so i guess it is my showfile what is corrupted, and made me say bad words!
I have channel 31 and 32 patched into a stereo channel, no audio coming into the console, no xlr attached to pre amp 31 and 32, no plugins assigned. just input 31 and 32.
http://dl.dropbox.com/u/99954944/Ven...2013.55.50.mp4
http://dl.dropbox.com/u/99954944/Ven...2019.08.28.mp4
Old 10-17-2012, 12:44 PM
Brent Lind Brent Lind is offline
hey, as long as we are talking bugs, I've got one. The first time it happened I thought it had something to do with the FW32 recording, but its happened now without FW involved.
Basically, while running a show with the console pretty well maxed out and lots of snapshots, suddenly "auto cancel" solo mode fails. Meaning that suddenly for no reason, solo's are additive instead of one at a time. Toggling the "auto cancel" and "input priority" options made no difference and in both cases the problem was solved upon restarting.
Not the end of the world, but for a monitor engineer juggling 20 or so mixes, its a pretty serious workflow issue.
11.1.2 on Mountain Lion bugs bugs bugs. command+f, elastic audio, discoloration farmfresh Pro Tools 11 21 05-01-2014 07:21 PM
Bug in Venue 3.0 Software Limelight VENUE Live Sound Systems 2 04-02-2012 09:01 AM
VENUE D-Show 2.8 Standalone Software for VENUE SC48 Avid VENUE Live Sound Systems 0 05-13-2009 12:30 AM
001 Software bugs -2? Mac Shack 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-31-2005 10:30 AM
001 has software bugs? Mac Shack 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-31-2005 09:29 AM
