Old 12-19-2010, 09:23 AM
Soundtrack2life Soundtrack2life is offline
Default PTHD Machine Room
I am looking to either modify a storage room connected to my control room or utilize a utility room next to the live room as a machine room for my PTHD2 Mac Pro 4 core 2.66 computer. Not because of noise but due to the heat build up in the control room. The bottom line is either direction I need to go approx 25 feet from the monitors (routing the wires through the walls). I am looking to use a DVI-D KVM to hook up a Mac Mini computer as well. I feel pretty confident about the video signal being OK but I am concerned with the Keyboard & Mouse USB cable. Has anyone used an active USB extender successfully with the Mac computers? If so which one.
I am welcome to any suggestions. From what I Googled the KVM I listed seems Mac friendly. So far on the shopping list. . .
http://www.tigerdirect.com/applicati...912&CatId=4474
http://www.tigerdirect.com/applicati...384&TId=2&SF=1
I am open to any suggestions.
Thanks,
Joe
Old 12-19-2010, 11:57 AM
Hanswurstlsepp Hanswurstlsepp is offline
Default Re: PTHD Machine Room
I'm using a gefen dvi & usb cable which got around 30 feet.
At the end (in the control room) there's a dvi booster:
http://www.gefen.com/kvm/dproduct.jsp?prod_id=4999
Works perfect for the Apple30" display.
For my 2 other dvi displays I'm using very good high end dvi cable - but those 2 are not from gefen.
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2023.6  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 12-20-2010, 03:18 AM
Craig F Craig F is offline
I have 2 rooms using 2 activate USB cables chained but they need powered hubs for reliable operation
Thank you,
Craig
Old 12-20-2010, 09:04 AM
Sean Russell Sean Russell is offline
Default
Gefen all the way.
... but does it help the chorus?
Old 12-20-2010, 10:06 AM
HearInc HearInc is offline
I'm not quite that far, but I just use plain extender cables for both USB and monitors (DVI) I do have a cheap powered USB hub in the control room that everything plugs into, but the monitors are fine without a booster of any kind.
Brian Steckler, Producer
Old 12-20-2010, 11:03 AM
ronwasserman's Avatar
ronwasserman ronwasserman is offline
Same here 25ft extensions for monitor. USB thru the Cinema Display. Works perfectly.
Ron Wasserman
http://www.ronw.com
http://www.imdb.me/ronwasserman
http://www.fishertheband.com
Mac Pro (Late 2013) 3.5 GHz 6-core Intel Xeon E5 - 32 GB Ram / 1TB Flash Storage - Avid HD I/O - Latest Mac OS - HDX3 - Latest PT Version.
Old 12-20-2010, 12:28 PM
I was checking out the Gefen KVM. . . 1st they cost alot more & 2nd they are not hot key switchable. . . .
Joe
Old 12-20-2010, 01:07 PM
budster budster is offline
Gefen is a four letter word at my work. Try some of the other options to see if they will suit you.
Old 12-20-2010, 01:08 PM
nevertold nevertold is offline
You can run everything over CAT5E cable these days guys. I run USB to CAT5E convertors at each end of my CAT5E cable runs (they only cost about $30) and you can run them over very long distance. You can also get HDMI/DVI to CAT5E convertors as well, and would be cheaper than buying long run HDMI cable. (Plus you can get firewire, and various other AV convertors.....).
Old 02-13-2011, 12:45 PM
After much research on DVI KVM's I decided to go with this KVM
http://www.adder.com/UK/products/av4pro-dvi.aspx
BTW it works great with Mac's & PC's together. I love how it does the keyboard mapping. I am using an older Mac keyboard (FWIW I don't like the new Mac keyboards) and it works great with the PC too. I only needed to go 15' in either direction so I also purchased the Adder 15' USB/DVI cables. Besides the absence of heat build up from the Mac Pro in the control room I am enjoying absolutely no noise as well. I did consider the CAT5 KVM's but for the short distance I was going there was no need to spend the extra $.
Joe
Using PTLE and PTHD on same machine, can it be done? MBpro NK Pro Tools TDM Systems (Mac) 3 04-04-2008 02:03 AM
Machine Room Temperature D Bag Pro Tools TDM Systems (Mac) 3 02-10-2008 12:03 PM
SSL 9000K machine controlling PTHD 6.7 over 9pin? MikeOlson Pro Tools TDM Systems (Mac) 1 03-28-2005 03:35 PM
Should my 192i/o's go in the machine room? everglass Pro Tools TDM Systems (Mac) 0 03-22-2002 05:34 AM
Control PT machine from another room? ponyboy Tips & Tricks 0 10-29-1999 03:07 PM
