Old 04-25-2019, 07:14 PM
Dj-Ike Dj-Ike is offline
Default Eucon greyed out when S3 is in Studio mode.
When eucon is activated, the s3 just shows blank boxes in the oleds. I cannot figure it out. Things used to work correctly, then I was hospitalized for 3 months. when I got back, this started, and I haven't been able to use the s3 as an audio interface. Please help!!!
Music is the Message
Old 04-26-2019, 12:33 PM
EddieJones's Avatar
Default Re: Eucon greyed out when S3 is in Studio mode.
In EuControl on the Surfaces tab do you see the S3 in the left column? and/or the right?
Old 04-26-2019, 03:57 PM
No. When it does show up, the S3 is not in studio mode. The Pro Tools session shows up on the surface, but only the bottom rows of OLEDs are lit.
Old 04-26-2019, 04:26 PM
Also the meters are active, but the audio interface is not.
Old 04-27-2019, 11:23 AM
EddieJones's Avatar
To light up the top row of OLEDs you need to select a track.
Old 04-27-2019, 01:44 PM
True. That works, but there’s no output select, no(actually I forgot all that’s supposed to show on the right hand OLEDs.
I’ll try to send some snapshots:
Before EUCON:
Old 04-27-2019, 01:46 PM
After EUCON starts:
Old 04-27-2019, 01:54 PM
With an open PT session:
I believe it is not connected because I had to manually wake it from sleep using the ‘Restart All EUCON Applications.
I hope someone has an answer to this puzzling behavior. Oh yeah, the left OLEDs are showing the session.
Old 04-27-2019, 02:26 PM
What the heck happened to my snapshots? Somebody guide me as to how to post the pictures. Never mind, they showed up
Old 04-29-2019, 08:53 AM
EddieJones's Avatar
Simultaneously press the right-side < Page and Page > to get the I/O controls
New Record / Automation Mode lights in Eucon 3.7 a bit confusing cshaw Avid S1, S3, Dock and Control App 0 10-18-2017 02:24 PM
I'd pay money for a Eucon / Studio One protocol BoomTap Artist Series 5 10-12-2017 12:20 PM
automation mode glitch almost fixed in Eucon 3.4 ??? yoerik Avid S1, S3, Dock and Control App 7 09-05-2016 07:15 AM
Eucon 3.3 - Mackie Controll/ HUI Mode does not work! basicx Artist Series 7 10-27-2015 05:27 AM
Video Satellite LE - Enable Satellite Mode is greyed out? Erik Olsson Post - Surround - Video 6 01-11-2010 09:16 AM
