Old 11-22-2020, 11:28 AM
copesetic copesetic is offline
Default S1 & Logic Pro X
Hi guys, I just got my S1 and started playing around with LPX. I have the problem that if I have a both an EQ and a compressor in a channel, I can press EQ on the S1 and the plug-in window will open up and I can use the knobs to change the settings. When I press dynamics on the S1, nothing happens. As if there is no plug-in in the channel. And if I go to channel view on the HD fire 10, and press dynamics, still nothing happens. But with EQ, like before with the EQ button on the S1, the plug-in window opens up and I can change the settings.
Any idea why this is?
Thx in advance
cope
Old 11-22-2020, 08:55 PM
sjgam sjgam is offline
Default Re: S1 & Logic Pro X
Yeah Dyn button is not functional with Logic. You have to load dynamic plugins using the Insert button.
Logic pro and logic pro x doesn't work after mavericks Sanderb Artist Series 3 12-20-2013 12:13 PM
Logic 8 to logic 7 session won't open! saving procedure need crizdee Pro Tools TDM Systems (Mac) 9 04-26-2008 08:09 PM
Logic Pro users: Midi & audio between Logic & PT dtmprod Pro Tools TDM Systems (Mac) 4 09-24-2006 04:16 PM
Logic 5.0.0 crashes all the time.. Is there a Logic expert around here? uno1234 Pro Tools TDM Systems (Mac) 13 04-28-2002 04:23 PM
Hello Logic users.......Please explain about Logic Midi elik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-04-2001 12:35 AM
