Old 11-18-2020, 12:30 PM
senghor senghor is offline
Default Pro Tools do not work when press play. Nothing happens.
Hi.
I have Windows 10 and Pro Tools 2020.5.
Sometimes when I open Pro Tools and I press play nothing happens. The cursor doesn't work. I have to restart Windows to make it work.
Why is that?
Thanks.
Win10 Home Premium, SP1
Intel i7-4770K @3,5GHz, RAM 16GB
GA-Z87N-WIFI (rev. 1)
UA Apollo Solo and pre-amps, Pro Tools 2020
Old 11-18-2020, 01:48 PM
Top Jimmy's Avatar
Default Re: Pro Tools do not work when press play. Nothing happens.
In my experience this has something to do with the interface driver. What interface are you using? Do you have the latest driver installed?
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.4.
Pro Tools Ultimate 2020.12, HD Native, Focusrite Red 8Pre (Mac)
Pro Tools 2020.12, Mbox3 (Win)
Old 11-18-2020, 02:09 PM
Yes, I have. I have the UAD Apollo Solo.
Old 11-18-2020, 03:02 PM
JingleDjango JingleDjango is offline
Just in case, make sure you have pre-roll and count-in disabled.
Old 11-18-2020, 06:10 PM
I have checked those, but nothing!
Old 11-19-2020, 11:38 AM
studiosus studiosus is offline
I´m on win10. I would also check the asio driver of your interface. That happens to me, when protools is somehow unable to communicate with my interface. I have a horus from merging, a network, ravenna interface. Because of the nature of the asio network driver, my interface can be unpowered, but protools still let me choose the driver.
Do you have another daw installed on your computer? Do you also have problems with the interface driver in the other one? If you don´t have another daw, you could try reaper. Just to find out, if your problem is coming from the driver or protools.
Old 11-19-2020, 02:25 PM
Similar happens to me quite often(hit Play and the Play button flashes), but I never need to restart the computer. I close Pro Tools and re-open and it always works after the restart. And to make it even more weird, if the session won't play, I can initiate a Bounce to Disk and that will fire off without a hitch.
Old 11-19-2020, 03:40 PM
JCBigler's Avatar
JCBigler JCBigler is offline
Often times when this happens to me, I will change the hardware buffer either up or down one level and it starts working. Not sure why that would make any difference, but it seems to wake up the interface or reconnect Protools to the interface.
It always seems to happen when I change between interface.
Justice C. Bigler
www.justicebigler.com
Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / HD|Native-TB / Protools Ultimate 2020.5
Home/mobile: Focusrite Red 8Pre / Clarett 4Pre
Road/hotel: Roland OctaCaputre / Apogee One
Old 11-19-2020, 03:48 PM
XJENSEN XJENSEN is offline
Yes, happens to me too. Toggle the buffer and it magically works again. Pro Tools hocus pocus!
Old 11-21-2020, 09:01 AM
Here OP,
Bizarre, w/ the buffer. I will do that next time it happens.
PT12.6 won't play sessions. They load ok, but when I press play nothing happens senghor Pro Tools 12 1 12-30-2016 08:43 PM
PT12.6.1 won't play sessions. They load ok, but when I press play nothing happens senghor Pro Tools 12 5 12-11-2016 11:30 PM
I press play, but pro tools interprets it as pause.. skaloma 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-03-2012 10:02 PM
When press play the stop key lite and play key blinking Sam Yin Tips & Tricks 6 12-05-2009 09:26 PM
I press play, it doesn't play. hehe - any advice? awritersparadise 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-11-2007 06:24 AM
