Old 05-30-2020, 01:39 PM
Progear Progear is offline
Default Econ or S1 or Control Issues
PT 2020.5
Lates Econ 20.5.0.149
S1 20.5.5.0
Brand new Imac 2019 i9, 40G mem, with clean installs. Only running music apps.
S1 connected with iPad, Firehd 10.
When Econ is Enabled under the peripherals menu, Radom Large output Faders pop out and I can't get rid of it.. click on the x, vanishes for a split second and comes back up, either in mix or edit windows.
Also
When Econ is engaged, I can't get most plugins windows to stay active, click on plugin in inserts, window pops up for a split second and vanishes. after a few tries PT crashes.
No issues when Econ is not selected.
hopefully there isan option to correct this.
Thanks
Progear
Old 05-30-2020, 09:05 PM
Default Re: Econ or S1 or Control Issues
Well, I have an update..
Problem happens when I happen when i engage pan/Mix bottom in pan mode on my S1
as soon as I take it out of "PAN" no more large fader popup and plugs stay focused.
software glitch ?
Old 05-30-2020, 09:57 PM
EddieJones's Avatar
It's a setting in EuControl, The user guide explains what each one does. You can turn off pan, sends or plugin windows popping up.
Sent from my HMA-L29 using Tapatalk
Old 05-31-2020, 12:27 PM
Thanks Got It ...
Old 06-01-2020, 08:15 AM
Lynn Gräber Lynn Gräber is offline
Eddie, is there a current guide for Eucon 20.5 that explains all these settings? Honestly, I have searched and current info has been pretty difficult to find.
Old 06-01-2020, 09:19 AM
Halfmoon Halfmoon is offline
See the "Using EuControl Surfaces.pdf" available here: https://avid.secure.force.com/pkb/ar...Product-Guides
This guide explains all EuControl settings and features, and shows how to use one or more controllers to record, edit, mix, automate, etc.
This link should also be in your Avid account next to the latest EuC software downloads.
M
Interesting Bug in Econ Control Panel joeshepard Avid S1, S3, Dock and Control App 4 05-13-2019 03:41 PM
Reverting back to Econ 3.7? Tim R. Pro Tools 2018 0 05-23-2018 05:54 AM
pro control issues wjurgens ProControl, Control|24, Command|8 20 10-21-2016 03:05 PM
HUI Control Issues Crookster Pro Tools M-Powered (Win) 0 05-18-2007 09:37 AM
