Old 05-31-2010, 10:07 AM
notrude55 notrude55 is offline
Default Command 8 and DAWs other than PT
I own a Command 8 002R and use both PTLE7 and PTLE8, I have started dabbling into other DAWs like Harrison mixbus , Logic etc, and would love to find out if C8 could possibly and easily work as a control surface for anything other than PT. Anyone know?
Old 05-31-2010, 06:14 PM
Hr.Austmann Hr.Austmann is offline
Default Re: Command 8 and DAWs other than PT
Ive read that one should be able to use C8 with other daw's.
ive try'd with reaper.cubase5 and pt8 on my studio setup
and wont work at all exept on pt 7,3 on my Celeron lap top wich i use for internet and crap.
weird thing aswell that i bought it used and seen it in action on latest macpro before,and just the other day i took it to check if the unit was damaged and went to a different studio with also latest macpro and there it would not work but only on my celeron non studio computer and previous owner.
I just dont know??????
Old 06-03-2010, 09:17 AM
lkingston lkingston is offline
I'm trying to map the Command 8 faders to Propellerheads Record. It seems to work if I connect the Command 8 via midi to my PC rather than trying to do it through the USB port of the Command 8 (where there doesn't even seem to be a Midi interface that is accessible to software other than Pro Tools.)
It seems to work well one way, that is from the faders to the DAW software. I don't see any way to automate the faders back from the DAW software to the Command 8 though. Is this the way it is supposed to work: flying faders only in Pro Tools?
Also, I can control the faders, the mutes, the solo buttons, etc. but I can't control the Propellerheads Record transport from the Command 8 transport buttons. Am I missing something?
laurencekingston.bandcamp.com
Old 10-10-2015, 03:24 PM
MATH020682 MATH020682 is offline
did you ever have luck with this?
I'm trying the same thing essentially and propellerhead told me that if i can get the command 8 to emulate a mackie (mcu) it will work...
Old 10-13-2015, 01:26 PM
Tweakhead Tweakhead is offline
I found this useful article at Sound On Sound:
http://www.soundonsound.com/sos/jul04/articles/digidesigncommand8.htm
Search the page for "stand-alone". There is an entire sub-section written about it.
Old 10-19-2015, 01:37 PM
Yea its a good article but doesn't quite have the info I'm after.
Old 01-31-2016, 09:28 AM
bangbangbang's Avatar
bangbangbang bangbangbang is offline
faders only fly in PT ?
bang bang bang ! see you later
Let the hardware interface with the software
Old 01-31-2016, 01:44 PM
Oh I finally got it working!
Old 01-31-2016, 02:00 PM
If any one else is trying to do this tell reason your control surface is a livid ds1.
The only bad thing is when a fader is writing data it isn't very smooth, really low frame rate. However it receives days smoothly
Old 10-29-2016, 08:30 AM
great !
About SSDs in DAWs Sir Les 2 General Discussion 27 01-18-2014 11:13 AM
Connecting 2 DAWs michael37327 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-17-2011 11:24 AM
Let's ask Digidesign to make Command|8 work with other DAWs dr_axel ProControl, Control|24, Command|8 4 10-03-2007 05:45 AM
Syncing 2 DAWs tjkili 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 11-01-2002 12:53 AM
Other DAWs... trkkazulu General Discussion 1 01-25-2002 05:56 AM
