samples
I have numerous sample cd's in Roland and aiff format. I'm using a mac book pro. I've been out of this for a while and used to just run the samples on the old roland hardware. (s-760, xv5080). I know there's got to be an eaiser way to use these samples rather than putting them back in the hardware and going through 1 by 1. Does anyone have any suggestions on which program or programs to use. I currently have an mbox and want to start up again. Any help is appreciated.
Thanks, |
Re: samples
You need a sampler, or more correctly, a sample-player that functions as a plugin.
I'd recommend getting Kontakt2. It can import the S760 samples and comes with a huge libary of it's own. The 5080 is a different matter. Most of those sounds are built in. There is a program can can automatically play each patch (even record every 3rd note, for instance), record it, and then save it to a sampler format, but I can't find the link for it. Maybe someone else will know.
Larry PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins. |
Re: samples
Re: samples
Thanks for the reply,
The thing is I have the samplers, but i'd like an eaiser way to convert them and import them direct into protools. |
using PT8 in 24 nit with 16 bit samples | converted | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-02-2010 11:05 PM |
Have I been off by 164 samples all along? | scottevl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 55 | 01-18-2004 05:26 PM |
OT - Help with Samples | roxy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-04-2003 02:33 PM |
EMU samples into Mac SSC | Renie | Digidesign Hardware & Software | 3 | 11-15-2001 08:57 AM |
samples | SNAPPER | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-09-2000 03:12 PM |
