Old 03-07-2020, 03:41 PM
pitchpole pitchpole is offline
Default Windows 10 can't hear pro tools through computer speakers.
So is it possible to hear pro tools through my systems built in speakers?
When I go to playback engine ASIO is selected. So I can only get audio to work with this set through my interface. There's no dropdown to change this. In Ableton I have the option to also select Realtek which is the default audio driver for internal speakers.
Any ideas? Thanks
Old 03-08-2020, 12:29 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Windows 10 can't hear pro tools through computer speakers.
Any ideas? Thanks
You can try Asio4all should work ok...
http://www.asio4all.org/
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-08-2020, 03:19 PM
Originally Posted by crizdee View Post
Chris
Hi, thanks although that's what I meant, I do have ASIO4all installed. That's what actually shows in the playback engine.
When I look up this issue online I see that other users have multiple options available in the drop down, for example. Here they have an Aggregate option and a built-in output option. I'm not sure why I don't have a built-in output option. Any other ideas? Thanks
https://ibb.co/nCJhjNs
Old 03-09-2020, 12:56 PM
Chris
Thanks, I should have mentioned that I do have ASIO4all installed. That's what I meant. That only seems to route audio through my interface, not internal speakers.
When I look up this issue online I notice that under playback engine other users have multiple options in the dropdown list, for example I saw one user with a "built-in output" option in that drop down menu. That was a Mac screenshot but what about Windows? Any Windows users have an option there to use built-in speakers or use the realtek driver to route the audio to the on-board speakers?
And since I can use Realtek with the built-in speakers when I have abeton running I don't think it's a driver issue but more of a pro tools configuration issue? Thanks for any further ideas and help.
Old 03-10-2020, 03:39 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Select "WASAPI" as playback engine in Pro tools. I cant remember off hand whether the speakers should be default or not so try both ways. Note-speakers need to be enabled even when not selected as default
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 32 Gig Memory:Seagate 2 TB,1TB,4TB,500gb EVO OS Windows 7 Ultimate
PT 2019.6 Native through A&H Qu-32
Bluetooth speakers, Pro Tools 9, Windows 10 Jehziel Windows 9 08-18-2016 06:27 PM
No sound from my computer speakers with Pro Tools 9 kalashatt Getting Started 1 05-28-2013 09:38 AM
Help...Why dont I hear anything out my speakers cristol 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-22-2007 10:34 PM
Hear PT in computer default speakers GtrDude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-30-2006 01:10 PM
pro tools through computer speakers? dwkick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 07-20-2003 11:31 AM
